Community Member
x25 connection stays up after the XOT part was going down
We set up XOT via an IP network to reach a public host. The last part of the connection is via an x25 serial connection. that's working fine. There's only 1 "problem" left.
If during the Call the XOT session is lost due to TCP is lost , the Call will be cleared directly (use keepalive 1 second). and the Terminal who initiated the call is cleared. But the X25 session from our last router to the public host stays up and a new Call is not possible till the Host sends a time out.
version 12.2
service tcp-keepalives-in
service tcp-keepalives-out
x25 routing
interface Loopback1
ip address
interface Ethernet0
no ip address
no cdp enable
interface Serial0
bandwidth 64
encapsulation x25 dce ietf
no ip mroute-cache
x25 address 200300300100
interface Serial1
bandwidth 1944
no ip address
encapsulation frame-relay
no ip mroute-cache
x25 route 160300300101 interface Serial0 (to the public host)
x25 route 20030051 xot xot-keepalive-period 1 xot-source Loopback1
What can i do to let the XOT session also informs the x25 connection to be cleared as XOT fails?
Community Member
Re: x25 connection stays up after the XOT part was going down
Looking over the configuration it seems that you have everything configured correctly. The following URL has some more information and some troubleshooting procedures that should help.
