Community Member
XP Remote Desktop through 2621
I have a 2621 router running ios 12.2. It is configured and running great, all workstations can access the internet. My problem is that I am unable to connect to a workstation (192.168.1.3) on the inside. I am trying to connect to this workstation from outside the office. I have dug around the forums and tried a few things to get port 3389 from the WAN to "redirect" to a local machine (192.168.1.3) at port 3389. Incase my description isn't detailed enough here is a picture! :-)
INTERNET(public) ---> ROUTER --> WORKSTATION(private)
Also the WAN address is assigned via DHCP, it is connected to a cable modem and it only provides one public IP.
Here is the config I am running, I changed the security related entries. Any help on this would be greatly appreciated.
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Area88Router
enable password ******
ip subnet-zero
ip dhcp excluded-address 192.168.1.1
ip dhcp pool 192lan
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 63.240.76.19 204.127.198.19
lease infinite
ip audit notify log
ip audit po max-events 100
interface FastEthernet0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
ip nat inside source list 100 interface FastEthernet0/0 overload
ip classless
no ip http server
ip pim bidir-enable
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
line con 0
password ********
line aux 0
line vty 0 4
password ********
login
end
Thank you in advance,
Chad
Community Member
Re: XP Remote Desktop through 2621
I don't think XP's remote desktop will work through a Port translatted NAT address. You might check with Microsoft support on this to be sure.
Community Member
Find out the port number and protocol, udp or tcp and put in a line like this
ip nat inside source static mmm x.x.x.x yyyy interface Ethernet0 aaaa
mmm = udp or tcp
x.x.x.x = the ip of the computer you want to connect to (inside private address)
yyyy = the port number (for the inside)
ethernet0 = the interface that is on the outside (this could be a serial port)
aaaa = the port on the outside (probally the same as the inside or yyyy)
Then you use your public ip address when connecting from outside the network, this statement will redirect the connection to the inside computer you specified.
89
