Community Member
Y2K Problem/Bug?
I started this year useing an old catalyst switch
(WS-C2916M-XL) and i never used any hardware with
IOS before. Its a "4 MB" Switch so i useded as the
Manual say to the (all most final) Version that is
available for this switch: 11.2(8.11)SA6
After the ios update i saw by use of command
> dir flash: < that the date is not correctly.
Switch>sh ver
IOS (tm) C2900XL Software (C2900XL-HS-M), Version 11.2(8.11)SA6, MAINTENANCE INTERIM SOFTWARE
Copyright (c) 1986- >> 1903 << by cisco Systems, Inc.
Compiled Thu 17-Jul-03 12:35 by antonino
Shouldnt that be 1986- >> 2003 <<?
Switch>sh clock
*00:31:49.199 UTC Mon Mar 8 1993
The switch was a long time not running (without
power). Now my question is whether there is
maybe a type of bios battary for example that is
empty? Can this wrong clock setting be the reson
that it lead to show wrong dates in "sh ver" details?
Thanks for help :)
Re: Y2K Problem/Bug?
Try changing the clock to a new date and time seeting and see if that makes any difference.
switch# clock set hh:mm:ss 24 march 2006
let us know if that changes it or its an IOS compilation issue.
regards,
-amit singh
Community Member
Hello
Thanks for your answer ...
I used the following command(s):
clock set 07:44:00 24 march 2006
Switch#sh ver
Copyright (c) 1986-1903 by cisco Systems, Inc.
Stil show´s -1903 ... it dont distrub me much (if all other
things working correctly) but that simple confuse me a bit.
The timestap for the (image)files stil show the old date too.
(Maybe it will only be updated if i remove them and then re-
install the image and the other files again on the flash?)
Directory of flash:
2 drwx 10816 Mar 28 1993 03:00:05 html
5 -rwx 107 Mar 28 1993 02:57:03 info
6 -rwx 1119215 Mar 28 1993 02:58:15 c2900XL-hs-mz-112.8.11-SA6.bin
175 -rwx 107 Mar 28 1993 03:00:11 info.ver
176 -rwx 185 Mar 28 1993 03:03:22 env_vars
177 -rwx 1120 Mar 11 1993 14:12:53 config.text
178 -rwx 600 Mar 11 1993 18:22:08 vlan.dat
Best regards :)
I feel like the copyright date is listed wrong in the IOS and it was complied as it is. It will not cause any problem in you switch operation, that's for sure :-)
As per your directory of flash goes, yes this are the old files. The moment you put new file that date will be updated to the new one.
HTH, Please rate if it does.
-amit singh
Community Member
That looks true (with the timestamp) :-)
Switch#copy flash:config.text flash:test.text
Source filename [config.text]?
Destination filename [test.text]?
1120 bytes copied in 0.58 secs
Switch#dir flash:
Directory of flash:
179 -rwx 1120 Mar 24 2006 08:04:35 test.text
I only ask my self what happen if there are some power
problems and/or i have to reset the switch. Is there
something like a battary in use for the system time?
I guess to fix this a solution can be to let the switch
connect to ntp server for time/date sync!?
Rateings will be done - thanks for the information about that :)
Purple
I wouldn't worry about , you can set the time with the "clock set " command but the first time it reloads it will go back to a default of like 1993 for the time , does not hold the time over a reload.
Community Member
I just want to let everyone out there know, that the same (wrong date for cisco copyrights) is shown on the latest version 11.2(8.12)SA6 too.
I can live with that fine but maybe somebody from the nice cisco people will correct this if/when a newer (4 Meg Switch) IOS Version will be Released.
IOS (tm) C2900XL Software (C2900XL-HS-M), Version 11.2(8.12)SA6, MAINTENANCE INTERIM SOFTWARE
Copyright (c) 1986-!!! >>> 1904 <<< !!! by cisco Systems, Inc.
Compiled Fri 09-Apr-04 19:46 by antonino
This is more Cosmetically for my self - so i can sleep fine without any panic ;)
159
