12.3(1) to 4.0.1 without xauth -phase 1 chokes
testing new IOS and client
host (with client 4.0.1) > 2621router > host
using following config
version 12.3
hostname Router
memory-size iomem 10
ip subnet-zero
ip audit notify log
ip audit po max-events 100
no ip domain lookup
mpls ldp logging neighbor-changes
no ftp-server write-enable
xsm
xsm vdm
xsm edm
xsm history vdm
xsm history edm
crypto isakmp policy 10
hash md5
authentication pre-share
group 2
crypto isakmp client configuration address-pool local myPOOL
crypto isakmp client configuration group myGROUP
key xxx
pool myPOOL
crypto ipsec transform-set mySET esp-des esp-md5-hmac
crypto mib topn interval 60
crypto dynamic-map myDYNMAP 10
set transform-set mySET
crypto map myMAP client configuration address respond
crypto map myMAP 10 ipsec-isakmp dynamic myDYNMAP
interface FastEthernet0/0
ip address 2.2.2.3 255.0.0.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
ip address 1.1.1.3 255.0.0.0
duplex auto
speed auto
crypto map myMAP
interface Serial0/1
no ip address
shutdown
ip local pool myPOOL 2.2.2.10 2.2.2.15
ip classless
ip http server
ip http secure-server
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
client configured with same group name and password (myGROUP xxx)
client can't connect and debug shows this
*Mar 1 03:43:26.075: ISAKMP (0:1): Checking ISAKMP transform 14 against priority 10 policy
*Mar 1 03:43:26.075: ISAKMP: encryption DES-CBC
*Mar 1 03:43:26.075: ISAKMP: hash MD5
*Mar 1 03:43:26.075: ISAKMP: default group 2
*Mar 1 03:43:26.079: ISAKMP: auth pre-share
*Mar 1 03:43:26.079: ISAKMP: life type in seconds
*Mar 1 03:43:26.079: ISAKMP: life duration (VPI) of 0x0 0x20 0xC4 0x9B
*Mar 1 03:43:26.079: ISAKMP (0:1): Preshared authentication offered but does not match policy!
*Mar 1 03:43:26.079: ISAKMP (0:1): atts are not acceptable. Next payload is 0
have entered same Group name and password ,
any ideas why debug says preshare auth doesn't match policy?
1 REPLY
Re: 12.3(1) to 4.0.1 without xauth -phase 1 chokes
Even though you're not doing XAuth, the router still needs to authenticate the group and key, so you still need the aaa config stuff. Add the following:
> aaa new-model
> aaa authentication login userauthen none
> aaa authorization network groupauthor local
> crypto map myMAP client authentication list userauthen
> crypto map myMAP isakmp authorization list groupauthor
This'll tell the router to do no user authentication (XAuth), but to authenticate the group locally on the router, which is where you've configured the group name and key.
80
