Community Member
1601R to 3005 LAN to LAN VPN
Is the 1601R capabile of being an end point in an IPSEC tunnel with a 3005 on the other side. Is this functionality supported by the IPSEC56 feature set for the 1601?
Re: 1601R to 3005 LAN to LAN VPN
Yes and yes (although you'll have to use a DES SA on the 3005 as well).
Community Member
Thank you - I appreciate the info.
83
