1721 to 1721 Tunnel with GRE - not working
Hi all. I have setup a tunnel between 2x 1721s via ADSL links. The Tunnel interface is showing as up but I cannot ping the Tunnel interface IP address at each end, only the WAN port address. My configs are below and any help would be greatly appreciated.
I am trying to route IPX via the GRE tunnels. The IP address allocated to Dialer3 is static in both router's cases.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname FNN1610023279
enable secret 5 $1$vfil$1eG/DsTJAHCZGriJng3Qo0
ip subnet-zero
no ip domain lookup
ip audit notify log
ip audit po max-events 100
ipx routing 000b.462d.83e9
crypto isakmp policy 45
hash md5
authentication pre-share
crypto isakmp key sa7384 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set ORCHESTRA esp-des esp-md5-hmac
mode transport
crypto map GRE 50 ipsec-isakmp
set peer 203.55.143.17
set transform-set ORCHESTRA
match address 104
interface Loopback0
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface Tunnel0
ip address 192.168.31.1 255.255.255.0
no ip route-cache
no ip mroute-cache
ipx network 116
tunnel source Dialer3
tunnel destination 203.55.143.17
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
no fair-queue
hold-queue 224 in
interface ATM0.3 point-to-point
description Internet Network
pvc 1/34
ubr 128
encapsulation aal5mux ppp dialer
dialer pool-member 3
interface FastEthernet0
description FNN1610023279 LAN
ip address 203.35.19.66 255.255.255.192
ip nat inside
ip route-cache policy
ip policy route-map nonat
no keepalive
speed auto
ipx encapsulation SAP
ipx network 102
interface Dialer3
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 3
dialer-group 1
ppp authentication chap callin
ppp chap hostname 01610023279C@KATI2001
ppp chap password 7 071C0048690A4D2C10
router eigrp 10
network 192.168.0.0 0.0.255.255
auto-summary
no eigrp log-neighbor-changes
ip nat pool ultimo 203.55.143.10 203.55.143.14 netmask 255.255.255.240
ip nat inside source list 122 pool ultimo overload
ip nat inside source static 203.35.19.66 203.55.143.1 extendable
ip nat inside source static 203.35.19.77 203.55.143.2 extendable
ip nat inside source static 192.168.20.1 203.55.143.3
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer3
ip route 10.20.0.0 255.255.0.0 203.35.19.67
ip route 192.168.21.0 255.255.255.0 Tunnel0
ip route 203.35.19.128 255.255.255.192 203.35.19.65
ip route 203.35.19.192 255.255.255.192 203.35.19.65
ip route 203.35.76.0 255.255.255.192 203.35.19.65
ip route 203.35.76.64 255.255.255.192 203.35.19.65
ip route 203.35.76.128 255.255.255.192 203.35.19.65
no ip http server
access-list 101 remark permit selected traffic
access-list 101 permit tcp any any established
access-list 101 permit udp any eq domain any eq domain
access-list 101 permit udp any eq domain any gt 1023
access-list 101 permit tcp any eq ftp-data any gt 1023
access-list 101 permit icmp any any echo-reply
access-list 101 permit tcp any host 203.55.143.1 eq telnet
access-list 102 remark Deny private RFC reserved IP addresses.
access-list 102 deny ip any 10.0.0.0 0.255.255.255
access-list 102 deny ip any 127.0.0.0 0.255.255.255
access-list 102 deny ip any 172.16.0.0 0.15.255.255
access-list 102 deny ip any 192.168.0.0 0.0.255.255
access-list 102 permit ip any any
access-list 104 permit gre host 203.55.143.1 host 203.55.143.17
access-list 110 remark Ethernet Inbound
access-list 110 permit ip any any
access-list 120 remark Ethernet Outbound
access-list 120 permit ip any any
access-list 122 deny ip 203.35.0.0 0.0.255.255 200.200.0.0 0.0.255.255
access-list 122 permit ip 203.35.0.0 0.0.255.255 any
access-list 123 permit ip 203.35.0.0 0.0.255.255 200.200.0.0 0.0.255.255
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
route-map nonat permit 50
match ip address 123
set ip next-hop 192.168.20.2
Router 2
version 12.2
no service pad
hostname FNN1610023271
enable secret 5 $1$E.Q/$sinzkYrD2jn.tp/E0EKtt/
ip subnet-zero
no ip domain lookup
ip dhcp excluded-address 200.200.1.1 200.200.1.50
ip dhcp pool 203.35.19.64
network 200.200.1.0 255.255.255.0
default-router 200.200.1.254
dns-server 203.35.19.84 192.189.54.33
domain-name symphony.net.au
lease 0 1
ip audit notify log
ipx routing 000b.462d.83e7
hash md5
mode transport
match address 104
interface Loopback0
ip address 192.168.21.1 255.255.255.0
interface Tunnel0
ip address 192.168.31.2 255.255.255.0
ipx network 116
interface ATM0
no ip address
no fair-queue
hold-queue 224 in
pvc 1/34
ubr 128
description FNN1610023271 LAN
ip address 200.200.1.254 255.255.0.0
ip nat inside
no keepalive
speed auto
ipx network 316
interface Dialer3
ip nat outside
encapsulation ppp
dialer pool 3
dialer-group 1
ppp chap hostname 01610023271C@KATI2001
ppp chap password 7 06351C746E56303536
router eigrp 10
auto-summary
ip nat pool sso 203.55.143.28 203.55.143.28 netmask 255.255.255.240
ip nat inside source list 122 pool sso overload
ip nat inside source static 200.200.1.254 203.55.143.17 extendable
ip nat inside source static 200.200.1.15 203.55.143.18 extendable
ip nat inside source static 200.200.1.3 203.55.143.19 extendable
ip nat inside source static 200.200.1.5 203.55.143.20 extendable
ip nat inside source static 200.200.1.7 203.55.143.21 extendable
ip nat inside source static 200.200.1.9 203.55.143.22 extendable
ip classless
ip route 192.168.1.0 255.255.255.0 200.200.1.2
ip route 203.35.19.0 255.255.255.0 203.55.143.1
no ip http server
access-list 101 permit tcp any host 203.55.143.17 eq telnet
access-list 104 permit gre host 203.55.143.17 host 203.55.143.1
access-list 122 deny ip 200.200.0.0 0.0.255.255 203.35.19.64 0.0.0.63
access-list 122 permit ip 200.200.0.0 0.0.255.255 any
access-list 122 permit ip 192.168.1.0 0.0.0.255 any
access-list 123 permit ip 200.200.0.0 0.0.255.255 203.35.19.0 0.0.0.255
access-list 1001 deny FFFFFFFF 7
access-list 1001 deny FFFFFFFF 47
access-list 1001 deny FFFFFFFF A1
access-list 1001 deny FFFFFFFF 112
access-list 1001 deny FFFFFFFF 1CB
access-list 1001 deny FFFFFFFF 30C
access-list 1001 permit FFFFFFFF
access-list 1002 deny FFFFFFFF A1
access-list 1002 deny FFFFFFFF 1CB
access-list 1002 permit FFFFFFFF
set ip next-hop 192.168.21.2
All advice greatly appreciated!
Geoff
  • Other Security Subjects
Re: 1721 to 1721 Tunnel with GRE - not working
Does it work if you remove the static NAT that uses the IP address of the outside interface/GRE/IPSec source? eg:
no ip nat inside source static 203.35.19.66 203.55.143.1 extendable
no ip nat inside source static 200.200.1.254 203.55.143.17 extendable
Thank you very much,
I can NAT to the loopback for external access and it all works fine.
Geoff
Try applying you crypto map to the dialer interface as well as the tunnel interface
370
