You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
2 CRYPTO MAP WITH A SINGLE IPSEC PEER
hello,
is it possible to have 2 crypto map in a single ipsec peer?
(2 SUBNETS)PEER_A-------PEER_B(1 SUBNET)
see example below;
crypto map dyn-map 10 ipsec-isakmp
crypto map dyn-map 10 match address 110
crypto map dyn-map 10 set peer PEER_A
crypto map dyn-map 10 set transform-set myset
crypto map dyn-map 15 ipsec-isakmp
crypto map dyn-map 15 match address 120
crypto map dyn-map 15 set peer PEER_A
crypto map dyn-map 15 set transform-set myset
THIS IS BEACUSE IPSEC PEER B HAVE TO DO A VPN TUNNEL IN 2 DIFFERENT SUBNET WITH PEER B.
AM ASKING THIS BECAUSE AM GETTING ASEND ERROR ON SHOW IPSEC SA.
THANKS
  • Other Security Subjects
Silver
Re: 2 CRYPTO MAP WITH A SINGLE IPSEC PEER
I guess you cant do it even if you use different crypto instances. Wonder why you want to do it ?
there are hosts in 2 different subnets in location A that users at location B wants to do VPN with.
Thanks.
Yes you can achive this. Its working fine for me. My setup has got 20-25 subnets and also allwoing server /32 of different subnets.
Othere end vpn box is a third pary box, which needs different tunnels for each segments.
crypto map SDM_CMAP_1 1 ipsec-isakmp
set peer P.Q.R.S
set transform-set HOset
match address 101
crypto map SDM_CMAP_1 2 ipsec-isakmp
set peer P.Q.R.S
match address 102
etc
interface FastEthernet0/1
description Interface Outside$FW_OUTSIDE$
ip address XX.XX.XX.XX
132
