223 disk space issue
Im installing 223 and of course i dont have th 200mb free space available in the /usr/nr directory. Meanwhile my /usr/nr/var and/or /export dirs have PLENTY.....
So, Is there someway of changing the default location for the install directory for the temporary staging of files ?? Or will I be forced to start from scratch?
I tried copying the /usr/nr directory to /export/nr and created a symbolic link for /usr/nr --> export/nr but i still get the same error....<see below for specifics>
thanks in advance,
# pwd
/usr/nr
# ls -la nr
lrwxrwxrwx 1 root other 10 Aug 22 13:52 nr -> /export/nr
#cd /tmp/CSIDD223-sol
#./install
Installation of CSIDD 2.2.3 - Start time Wed Aug 22 14:09:12 EDT 2001
Operating System is SunOS 5.6
Not enough space in /usr/nr ..
Talk to your System Administrator to provide space in /usr/nr directory for temporarily staging t
or installation.
About 200 Mb of free space is needed in /usr/nr. Currently available space is 40985.
# df -k
Filesystem kbytes used avail capacity Mounted on
/dev/dsk/c0t0d0s0 577286 114179 405379 22% /
/dev/dsk/c0t0d0s3 577286 396876 122682 77% /usr
/proc 0 0 0 0% /proc
fd 0 0 0 0% /dev/fd
/dev/dsk/c0t0d0s6 5985605 197761 5727988 4% /export
/dev/dsk/c0t0d0s2 192423 159578 13603 93% /opt
/dev/dsk/c0t0d0s4 96455 45825 40985 53% /usr/nr
/dev/dsk/c0t0d0s5 962134 399283 505123 45% /usr/nr/var
swap 295064 78888 216176 27% /tmp
1 REPLY
Re: 223 disk space issue
It looks like you actually linked /usr/nr/nr to /export/nr instead of linking /usr/nr.
Have you already moved all of the /usr/nr directory to /export/nr?
If not then you will need to do that first.
Remove the nr link from the /usr/nr directory.
Once that is done then you can umount the /usr/nr partition and remove it from the /etc/vfstab file.
From now on your /usr/nr directory will be part of the export partition.
Remove the now empty nr directory from the /usr directory.
Then create the link for /usr/nr to the /export/nr directory.
So if you cd to /usr/nr you wind up in /export/nr.
So instead of your output looking like:
# pwd
/usr/nr
# ls -la nr
It should look like:
# pwd
/usr
# ls -la nr
89
