2547oDMVPN with Loopback as iBGP source interface
I've been trying to get 2547oDMVPN with 'mpls nhrp' setup in a VIRL environment and I have gotten it work with some of the examples I've seen online, but all the examples online have had the hub as the route reflector and have used the Tunnel interface for BGP peering.  If I use my Tunnel interface as my iBGP peer source things work, but if I don't, then for some reason things stop?
Here is the output of some of my show commands that I believe to be the issue, but I don't know how to fix.  In the 'show ip cef vrf CLASS detail' I see the prefix and it gets recursively resolved to my tunnel interface.  In the 'show mpls forwarding-table' it says to drop the labels?  I attached my entire VIRL topology in case that would be helpful.  Thank you in advance for any help.
IR-01#show mpls forwarding-table
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or Tunnel Id Switched interface
305 202 0.0.0.0/0[V] 0 drop
307 205 10.10.1.0/24[V] 0 drop
308 No Label 10.30.1.0/24[V] 0 aggregate/CLASS
313 307 10.50.1.0/24[V] 0 drop
IR-01#show ip cef vrf CLASS detail
IPv4 CEF is enabled and running
VRF CLASS
17 prefixes (17/0 fwd/non-fwd)
Table id 0x2
Database epoch: 0 (17 entries at this epoch)
0.0.0.0/0, epoch 0, flags [rib defined all labels, default route]
local label info: other/305
recursive via 10.10.0.251 label 202
recursive via 10.10.0.250/31
nexthop 1.0.2.10 Tunnel102
0.0.0.0/8, epoch 0
Special source: drop
drop
0.0.0.0/32, epoch 0, flags [receive]
Special source: receive
receive
10.10.1.0/24, epoch 0, flags [rib defined all labels]
local label info: other/307
recursive via 10.10.0.251 label 205
10.30.1.0/24, epoch 0, flags [attached]
local label info: other/308
attached to Null0
10.30.1.0/31, epoch 0, flags [attached, connected]
attached to Loopback1
10.30.1.1/32, epoch 0, flags [receive, local, source eligible]
Interface source: Loopback1 flags: local, source eligible
receive for Loopback1
10.30.1.32/30, epoch 0, flags [attached, connected, cover dependents, need deagg]
Covered dependent prefixes: 2
need deagg: 2
attached to GigabitEthernet0/2.20
10.30.1.32/32, epoch 0, flags [receive]
Interface source: GigabitEthernet0/2.20 flags: none
Dependent covered prefix type cover need deagg, cover 10.30.1.32/30
receive for GigabitEthernet0/2.20
10.30.1.33/32, epoch 0, flags [receive, local, source eligible]
Interface source: GigabitEthernet0/2.20 flags: local, source eligible
10.30.1.35/32, epoch 0, flags [receive]
10.50.1.0/24, epoch 0, flags [rib defined all labels]
local label info: other/313
recursive via 10.50.0.251 label 307
recursive via 10.50.0.250/31
127.0.0.0/8, epoch 0
drop
224.0.0.0/4, epoch 0
drop
224.0.0.0/24, epoch 0, flags [receive]
receive
240.0.0.0/4, epoch 0
drop
255.255.255.255/32, epoch 0, flags [receive]
receive
55
