2600 cli error messages
during boot up of my 2651XM router I get the following error messages in the cli. 1) Can anyone explain to a newbie (me) what these error messages mean, and what I need to do to resolve them?
The first two lines are self explanatory and don't matter but the remaining....
Slot is empty or does not support clock participate
WIC slot is empty or does not support clock participate
%Error opening tftp://255.255.255.255/network-confg (Timed out)
%Error opening tftp://255.255.255.255/cisconet.cfg (Timed out)
%Error opening tftp://255.255.255.255/vpn-confg (Timed out)
%Error opening tftp://255.255.255.255/vpn.cfg (Timed out)
2) if I do the command 'show ip interface brief' I see the (correct) ip address of FastEthernet0/1 but when I connect an ethernet cable to port 0/1 and ping this address my PC sees nothing. Why is that?
thanks for any help.
1 ACCEPTED SOLUTION
Re: 2600 cli error messages
It seems your router is by-passing the configuration and is searching for it broadcasting ftfp requests.
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a65a5.shtml
Solution
The most likely reason why the router has bypassed the startup configuration stored in NVRAM is that the configuration register has not been set properly. To change your configuration register so that the router does not ignore or skip the startup configuration upon reboot or power cycle, complete these steps:
From the Router# prompt:
1.
Type configure terminal , and press ENTER.
2.
Type config-register 0x2102, and press ENTER.
3.
Type end, and press ENTER.
This should solve it.
Please rate if this helped.
Daniel
Solution
1.
2.
3.
Daniel
Daniel thanks for your help, I think this solved these errors.
rated
103
