Community Member
2600 - PIX 515 VPN: need help
Hello. I'm trying to configure a site-to-site VPN using a 2611 and a PIX 515UR. I have the Pix working fine and people using the Cisco VPN client can connect and access the internal network.
However, I cannot get a 2611 to work. I need hte 2611 to do FW/NAT as well as the VPN tunnel. Is this possible? Does anyone have a sample config?
I've looked through all the documentation online and most of it covers 2600-2600 or PIX-PIX VPNs.
Re: 2600 - PIX 515 VPN: need help
This is possible.
There is no exact example as you are looking for. But you just need to consider the following samples:
router and pix ipsec
http://www.cisco.com/warp/customer/110/39.html
router with Firewall and NAt
http://www.cisco.com/warp/customer/793/ios_fw/cbac4.html .
Make sure that on the access-list for the firewall, you permt udp 500 (isakmp and tcp 50 (esp)
Community Member
Hello. Thank you for the link. I have looked over the documentation throughly and I still can't get this thing to work. Below is my config for the 2600 (10.0.0.1) and the PIX (11.0.0.1). I did "sanitize" before posting, so there might be some syntax errors.
Basically, nothing works. I try resetting the ipsec sa (clear crypto sa, etc.) and isakmp sa, but nothing happens. I've also turned on packet debugging on the PIX and I don't see anything come through.
2600 config:
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname myrouter
boot system flash flash:c2600-jk9o3s-mz.122-10b.bin
no logging console
memory-size iomem 15
ip subnet-zero
no ip domain-lookup
ip dhcp excluded-address 192.168.80.1 192.168.80.50
ip dhcp excluded-address 192.168.80.200 192.168.80.254
ip dhcp pool mydhcppool
network 192.168.80.0 255.255.255.0
default-router 192.168.80.250
domain-name mydomain.com
dns-server 12.12.12.12 12.12.12.12
lease infinite
ip multicast-routing
ip audit notify log
ip audit po max-events 100
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
lifetime 1000
crypto isakmp key PASSWORD address 11.0.0.1
crypto ipsec transform-set TS1 ah-md5-hmac esp-3des esp-md5-hmac
crypto map M1 1 ipsec-isakmp
set peer 11.0.0.1
set transform-set TS1
match address 120
call rsvp-sync
interface Ethernet0/0
description Internal Interface
ip address 192.168.80.250 255.255.255.0
ip nat inside
half-duplex
ntp broadcast
no mop enabled
interface Serial0/0
no ip address
encapsulation frame-relay
no ip mroute-cache
shutdown
no fair-queue
service-module t1 timeslots 1-4
interface Ethernet0/1
description External Interface
ip address 10.0.0.1 255.0.0.0
ip nat outside
no ip route-cache
no ip mroute-cache
half-duplex
no mop enabled
crypto map M1
router rip
version 2
passive-interface Ethernet0/1
no auto-summary
ip nat pool natpool 10.0.0.1 10.0.0.1 netmask 255.0.0.0
ip nat inside source route-map nonat pool natpool overload
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.254
no ip http server
ip pim bidir-enable
access-list 120 permit ip 192.168.80.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 130 deny ip 192.168.80.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 130 permit ip 192.168.80.0 0.0.0.255 any
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
route-map nonat permit 10
match ip address 130
snmp-server community public RO
snmp-server enable traps tty
dial-peer cor custom
end
PIX config:
: Saved
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname myfirewall
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list acl_in permit icmp any any
access-list acl_in permit tcp any any eq www
access-list acl_in permit udp any any eq domain
access-list acl_in permit tcp any any eq domain
access-list acl_in permit tcp any any eq ftp-data
access-list acl_in permit tcp any any eq 8080
access-list acl_in permit tcp any any eq 3306
access-list acl_in permit tcp any any eq 4040
access-list acl_in permit tcp any any eq 5800
access-list acl_in permit tcp any any eq https
access-list acl_in permit tcp any any eq ssh
access-list acl_in permit tcp any any eq pop3
access-list acl_in permit tcp any any eq imap4
access-list acl_in permit tcp any any eq 8000
access-list acl_in permit tcp any any eq 5900
access-list acl_in permit tcp any any eq telnet
access-list acl_in permit tcp any any eq 85
access-list acl_in permit tcp any any eq 8880
access-list acl_in permit tcp any any eq nntp
access-list acl_in permit tcp any any eq 61505
access-list acl_in permit tcp any any eq 5908
access-list acl_in permit tcp any any eq 2401
access-list acl_in permit udp any any eq 2401
access-list acl_in permit udp any any eq 873
access-list acl_in permit tcp any any eq 873
access-list acl_in permit udp any any eq ntp
access-list acl_in permit tcp any any eq 8013
access-list acl_in permit tcp any any eq 8008
access-list acl_in permit tcp any any eq 8181
access-list acl_in permit tcp any any eq 11371
access-list acl_in permit ip 192.168.0.0 255.255.0.0 192.168.80.0 255.255.255.0
access-list acl_in permit ip any host 10.0.0.1
access-list acl_out permit icmp any any
access-list acl_out permit ip 192.168.80.0 255.255.255.0 192.168.0.0 255.255.0.0
access-list acl_vpn permit ip 192.168.0.0 255.255.0.0 192.168.80.0 255.255.255.0
access-list ipsec permit ip 192.168.0.0 255.255.0.0 192.168.80.0 255.255.255.0
pager lines 24
interface ethernet0 10baset
interface ethernet1 10baset
mtu outside 1500
mtu inside 1500
ip address outside 11.0.0.1 255.0.0.0
ip address inside 192.168.2.200 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
pdm location 192.168.2.0 255.255.255.0 inside
pdm history enable
arp timeout 14400
global (outside) 1 11.0.0.2-11.0.0.5
global (outside) 1 11.0.0.1
nat (inside) 0 access-list acl_vpn
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group acl_out in interface outside
access-group acl_in in interface inside
route outside 0.0.0.0 0.0.0.0 11.0.0.254 1
route inside 192.168.0.0 255.255.0.0 192.168.2.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
no snmp-server location
no snmp-server contact
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
no sysopt route dnat
crypto ipsec transform-set TS1 esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 3600
crypto map M2 20 ipsec-isakmp
crypto map M2 20 match address ipsec
crypto map M2 20 set peer 10.0.0.1
crypto map M2 20 set transform-set TS1
crypto map M2 interface outside
isakmp enable outside
isakmp key PASSWORD address 10.0.0.1 netmask 255.255.255.255
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 86400
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
telnet 192.168.2.0 255.255.255.0 inside
telnet timeout 15
ssh 192.168.2.0 255.255.255.0 inside
ssh timeout 15
vpdn enable outside
terminal width 80
123
