2600 routing - desperate for help please
my previous post of the 18th July produced no replies and I've been hammering at this for 3 days and getting nowehere so if anyone can help (this newbie) I'd be grateful.
Here is my setup:
small LAN of PC's all connected by cables to a hub, all set ip on 192.168.1.xx
Cisco 2615XM router also connected to hub on Fastethernet0/1, set as as 192.168.1.70, set as LAN
Cisco 2651XM Fastethernet0/0 port ip set port to 192.168.1.72 connected by cable to Cisco wireless access point (configured as a universal workgroup bridge).
The Cisco access point ip set at 192.168.1.66 is connected wirelessly to a non-cisco adsl router on the internet (default gateway 192.168.1.254).
I'm trying to get the PC's on the LAN to access the default gateway router so they can surf the internet but I'm stuck at the 2615XM router. The PC can see both FastEthernet ports but I can't get the PC to see either the cisco wireless access point on 192.168.1.66 or the adsl router on 192.168.1.254.
In SDM/Interfaces and Connections I did Test Connection but the test fails at Checking Exit Interface, the recommended actions say: 'Select User-Specified option or add host specific/network specific/default route through this interface and retest connection'. I've tried different things but I can't create the route so if anyone can help me put the right settings into SDM that'd be great. I can't connect the wireless access point to the hub because the wap is configured as a universal workgroup bridge and this setting only supports a sinle device connected, thus the single device has to be the 2651XM which should serve as a route for the PC's on the LAN.
I've read the doc at:
http://www.cisco.com/en/US/products/sw/secursw/ps5318/products_configuration_example09186a008073e067.shtml but I get stuck at dynamic NAT. If I click RIP and then Edit the edit button just goes grey and the RIP stays disabled.
Thanks for any help.
Re: 2600 routing - desperate for help please
Anthony,
Post all of your configurations - remove any passwords etc.
HTH.
thanks for your response. I've tried to configure the 2651 based on the instruction here:
two things I keep failing on :
1) the instructions for dynamic routing said to click RIP and click Edit, but when I click Edit the button just greys out and nothing happens. I don't know how to solve this.
2) I still get constant failure with 'Test Connection'. When it gets to testing exit interface it always fails to ping DNS server addresses. I don't know how to solve this.
and here is the config I saved after my efforts with the sdm interface:
!This is the running config of the router: 172.16.1.30
!version 12.4
service config
hostname vpn
boot-start-marker
boot-end-marker
no logging buffered
no logging console
enable secret 5 yyyyyyyyyyyy
enable password zzzzzzzzzzz
resource policy
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip subnet-zero
no ip routing
no ip dhcp use vrf connected
no ip cef
ip name-server 192.168.1.254
ip name-server 192.168.1.255
no ip ips deny-action ips-interface
ip ddns update method sdm_ddns1
DDNS both
interface FastEthernet0/0
description $ETH-LAN$
ip address 172.16.1.30 255.255.0.0
ip helper-address 192.168.1.254
ip nat inside
ip virtual-reassembly
no ip route-cache
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
description $ETH-WAN$
ip ddns update hostname vpn.vpn
ip ddns update sdm_ddns1
ip address 192.168.1.70 255.255.255.0
ip nat outside
no ip route-cache
speed auto
half-duplex
no cdp enable
no mop enabled
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip route 10.1.1.0 255.255.255.0 192.168.1.2
ip http server
no ip http secure-server
ip nat pool pool1 192.168.1.60 192.168.1.80 netmask 255.255.255.0
ip nat inside source static tcp 172.16.1.1 8080 192.168.1.3 80 extendable
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 172.16.0.0 0.0.255.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 172.16.0.0 0.0.255.255
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password xxxxxx
login
no process cpu extended
no process cpu autoprofile hog
end
ip cef
ip routing
no ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
no ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip route 0.0.0.0 0.0.0.0 192.168.1.254
no ip nat pool pool1 192.168.1.60 192.168.1.80 netmask 255.255.255.0
ip access-list ext NAT
deny ip host 172.16.1.30 any
permit ip 172.16.0.0 0.0.255.255 any
ip nat inside source list NAT int f0/1 overload
remove:-
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 - this is not required, you want all traffic that the router does not have a connected interface to or static route point to. Also remove the static route ip route 10.1.1.0 255.255.255.0 192.168.1.2 - as if this subnet is connected to an interface - with the below config RIP will distribute it.
If you want rip, the paste the below on 2651 routers:-
router rip
version 2
network 172.16.1.0
network 192.168.1.0
no auto-summary
for the 2615 paste the below:-
router rip
version 2
network 10.1.1.0
network 192.168.1.0
no auto-summary
For any nertworks not directly connected to the ADSL router - you need to distibute a default route into rip - you could either run RIP on the ADSL box and distribute the default route from there - or redistribute from the 2651 - your choice.
HTH.
thanks for your response. Following your guidelines I've had partial success, the PC could see the wap and the default gateway but couldn't surf the net (yet). At 1am in the morning I saved the config from SDM both to PC and to the router startup-config and then went to bed. But this morning on reboot of the router I've got nothing and CLI says ''loadprog: bad file magic number: 0x0, boot: cannot load "flash:" Oh dear, it seems something got corrupted so I will have to start right from the beginning. But when I've got it running again I'll be much closer to getting it working. Thanks again for your help.
OK - lets us know how you get on.
I'm back up and running (it took me 6 attempts to renew IOS and get out of rommon mode but hey, I'm good at that now ha ha).
I tried your config (earlier post) that went:
ip cef
ip routing
no ip route 0.0.0.0 0.0.0.0 FastEthernet0/1...
but I couldn't ping the wap or the dg with this. I concede that might be because my nic wasn't configured correctly and I'm a bit embarrassed to say I'm not sure how my nic settings should be properly config'd - I don't know what I should enter into the nic settings for DG and DNS 1 and 2. I've managed to bluff my way through these settings in the past but now I'm on 172.16.1.xxx with this 2651xm I'm unsure.
Also, I know my original config was messy but I did a bit more fumbling with it in SDM and I was then able to ping the wap and the gateway from the pc but I couldn't surf the internet.
Thanks for the tip regarding enabling RIP, that worked.
If you have any more ideas about tweaking the config you gave me earlier I look forward to your advice. I'm losing faith in sdm so if I could write a neat config that would enable the PC to see the wap and dg that would be a good step towards resolution.
Thanks and await yours.
Anthony,
Post your current configs, I will make suggestions where I think they are nessary. Also when you post your configs - can you supply the following as well:-
1) What you really want to do?
2) What you cannot do right now?
HTH.
I've done it. I've finally got my PC's on the internet.
To answer your two questions, I have a small LAN of PC's (on 172.16.1.xx) that I needed to get on the internet. A cisco wap was also connected by cable to the LAN, configured as a universal wireless bridge, which then connected wirelessly to a non-cisco wireless adsl router (192.168.1.254). The router was connected to the internet.
My problem was that the wap would only connect to the router when set in universal wireless bridge mode because normal wireless bridge does not support connection to non-cisco devices. But univ wb mode only supports the connection of one PC, you can't connect multiple clients.
Therefore I had to make the 2651XM behave as if it was the one PC and route the lan through it. the LAN connected to F0/0 and the wap connected to F0/1.
Thanks very much for all your help with this andrew.
Here is the config that worked: (exported from SDM).
!version 12.4
hostname vpn
boot-start-marker
boot-end-marker
no logging buffered
no logging console
enable secret xxx
enable password harrycat
resource policy
no aaa new-model
ip subnet-zero
ip cef
DDNS both
ip nat inside
speed auto
half-duplex
no mop enabled
ip dhcp client update dns server none
ip address dhcp client-id FastEthernet0/1
ip nat outside
duplex auto
speed auto
router rip
version 2
network 172.16.0.0
network 192.168.1.0
no auto-summary
ip classless
ip http server
ip nat inside source list 3 interface FastEthernet0/1 overload
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 3 remark SDM_ACL Category=2
access-list 3 permit 172.16.0.0 0.0.255.255
control-plane
line con 0
line aux 0
line vty 0 4
password 2651
login
end
210
