3000 concentrator remote lan subnet issues
Hello, i have a remote network that connects to my 3000 gadjet. They recently changed their scheme around so that their subnet is 192.168.3.0, the same subnet my concentrator is on. since then the client cant connect. Had something similar with another remote lan once, being assigned to .1.0. Once it was switched to a .4.0 the problem went away. But that was a very small network, and this other is a fairly large one. Is there any way to get this thing to connect without redoing the subnets on these two networks?
Gold
Re: 3000 concentrator remote lan subnet issues
yes, you can configure nat and ipsec together. i.e. both vpn device nat the original subnet before encrypting the traffic.
the doc below is a sample config for a concentrator and a pix:
http://www.cisco.com/en/US/partner/tech/tk583/tk372/technologies_configuration_example09186a00800949f1.shtml
Everything hates me today, all i get when trying to go to that page is a notification that my password has been reset.
Gold
post your email add and i'll email you the doc.
wglover@fmrs.org
thanks much.
Gold
please check your email account.
118
