Community Member
3000 public interface changes
Does making any change to the public interface of VPN, reset the interface so you loose connectivity?
Like bandwidth, fragmentation setting?
1 REPLY
Re: 3000 public interface changes
I think yes, as there is a warning on the interface, e.g public interface, when you're trying to edit/view the setup parameter.
Configuration | Interfaces | Ethernet 2
You are modifying the interface you are using to connect to this device. If you make any changes, you will break the connection and you will have to restart from the login screen.
Configuring Ethernet Interface 2 (Public).
Rgds,
AK
95
