ovt Bronze
Bronze
3002 Network Extension Mode RRI
Hi!
Network Extension Mode RRI cease to function when a static route via the
private interface is added to the VPN 3002. Is this by design?
In general, is it possible to have more than 1 Net behind the 3002 and use
Network Extension Mode?
Oleg Tipisov,
REDCENTER,
Moscow
Community Member
Re: 3002 Network Extension Mode RRI
Regarding the RRI ceased to function, I think that is a bug. How come adding a static route prevents the 3002 to advertise its private network to the Concentrator in the other side ?
Regarding the several networks behind the 3002, the answer is 3002 will not advertise the other networks via RRI other than its private interface network. So you are limited with only ONE network to be able to encrypt behind a VPN3002.
Engel
ovt Bronze
Bronze
Thanks for the replay.
Regarding the RRI, I don't understand it either, but 3005 on the other side
stops adding RRI static route when a static route on the 3002 is configured
(3.6.7 software). It's a mystery.
103
