3005 Load Balancing Problem
I have enabled Load Balancing between two 3005's and although it seems to be working, clients cannot connect due to a XAUTH Failure. If I try to connect a client to a specific concentrator the same probelem occurs. It is not until I turn off the Load Balancing that the XAUTH works.
Any ideas?
Re: 3005 Load Balancing Problem
I don’t think XAUTH works with load balancing yet. Check your versions release notes for open caveats.
Actually it does. The solution was to upgrade the software. Thanks anyway.
89
