3005: upgrade code 3.6.7.D to 4.0.1
current bootcode/software:
Bootcode Rev: Version 2.5.Rel Jun 21 2000 18:57:52
Software Rev: Version 3.6.7.D Apr 03 2003 12:56:29
Do I need to upgrade the Bootcode to v4.0 before upgrading the software? If so, what are the proper steps? Please advise.
1 ACCEPTED SOLUTION
Re: 3005: upgrade code 3.6.7.D to 4.0.1
No, the bootcode should never need to be upgraded. We have 3000's running in the lab here with the old Altiga 1.1 bootcode on them, running 4.0 software.
This probably is not related to this. But has Cisco TAC tried Microsoft PPTP \ Cisco VPN connections with Version 4.01 in your Lab when the user Login name format is firstname.lastname@domain.com ?
We had issues with this working, when User was dialing using this format. VPN was sending only the firstname.lastname part to RADIUS instead of the FULL login name.
We then downgraded to 3.6.3 and everything started working again.
Regards \\ Naman
Regards \\ Naman
91
