3015 Proxy DHCP problem
The VPN is inserting the Scope Address as a giaddr in the request. The DHCP server then uses this as the return address (IP Header) with the result that the DHCP timer on the VPN expires as no response is coming back. The request is via the Private interface on 10.12.12.12
See snoop for request and response
Request
DHCP: ----- Dynamic Host Configuration Protocol -----
DHCP:
DHCP: Hardware address type (htype) = 1 (Ethernet (10Mb))
DHCP: Hardware address length (hlen) = 6 octets
DHCP: Relay agent hops = 0
DHCP: Transaction ID = 0xbc2da69e
DHCP: Time since boot = 0 seconds
DHCP: Flags = 0x0000
DHCP: Client address (ciaddr) = 0.0.0.0
DHCP: Your client address (yiaddr) = 0.0.0.0
DHCP: Next server address (siaddr) = 0.0.0.0
DHCP: Relay agent address (giaddr) = 10.11.11.1
DHCP: Client hardware address (chaddr)= 00:03:A0:89:7B:F4
Response
IP: ----- IP Header -----
IP:
IP: Version = 4
IP: Header length = 20 bytes
IP: Type of service = 0x00
IP: xxx. .... = 0 (precedence)
IP: ...0 .... = normal delay
IP: .... 0... = normal throughput
IP: .... .0.. = normal reliability
IP: Total length = 328 bytes
IP: Identification = 7747
IP: Flags = 0x0
IP: .0.. .... = may fragment
IP: ..0. .... = last fragment
IP: Fragment offset = 0 bytes
IP: Time to live = 255 seconds/hops
IP: Protocol = 17 (UDP)
IP: Header checksum = 5404
IP: Source address = 10.10.10.1, servername
IP: Destination address = 10.11.11.1, 10.11.11.1
Silver
Re: 3015 Proxy DHCP problem
Did you try adjusting the lease time on the internal 3015 DHCP setting ?
Yes..Made it 3600 minutes and also changed the timeout to 30 seconds.
110
