3030 concentrator crashed with SEP errors.
I opened a TAC case and received a replacement SEP module. This 3030 has two SEP modules in it and it seems that the one in slot one is the only one that is ever being used - and that is the one that generated the errors to cause the 3030 to crash.
Are the SEP modules hot-swappable? If not, can I disable the SEP in slot one and have the 3030 use the second SEP in slot 3 - so that I don't have to power down the concentrator?
1 REPLY
Silver
Re: 3030 concentrator crashed with SEP errors.
Use this VPN 3000 Series Concentrator Getting Started, Release 4.1 Troubleshooting and System Errors
http://www.cisco.com/en/US/docs/security/vpn3000/vpn3000_41/quick/start/apxerr.html
145
