3705 missing from NSDB
I do not see signature 3705 listed on the NSDB when I go to the main signature list at the following link.
https://172.19.X.X/protected/nsdb/html/all_sigs_index.html
Is it missing from the NSDB?
Bronze
Re: 3705 missing from NSDB
What version of Sensor software are you running? I just checked the S25, S26 and the soon to be released S27 NSDB's, and 3705 was present in all of them.
Sensor Version 3.1(2)S26
Host Name xxxxxxxxxxxxxxxxxx
Host Id 1
Organization Name xxxxxxxxxxxxxxxx
Organization Id 1
Post Office Port 45000
Web Server Port 443
CIDS Daemon Status netrangr 1007 1 0 15:13:14 ? 3:53 /usr/nr/bin/nr.packetd
netrangr 992 1 0 15:13:14 ? 15:53 /usr/nr/bin/nr.sapd
netrangr 988 1 0 15:13:14 ? 0:00 /usr/nr/bin/nr.loggerd
netrangr 1000 1 0 15:13:14 ? 0:00 /usr/nr/bin/nr.fileXferd
netrangr 974 1 0 15:13:14 ? 0:17 /usr/nr/bin/nr.postofficed
CIDS Connection Status Connection Status xxx_data_ctr
xxxxxxxxxxxxxxxxxxxxxxxx Connection 1: xxx.xxxx.11.44 45000 1 [Established] sto:0002 with Version 1
xxxxxxxxxxxxxxxxxxxxxxxx Connection 1: xxx.xxx..11.47 45000 1 [Established] sto:0003 with Version 1
CIDS Version Application Versions for xxxxxx_data_ctr
The Version of the Sensor is: 3.1(2)S26
postoffice v220 (Release) 01/12/14-20:01
logger v220 (Release) 01/12/14-19:59
sap v220 (Release) 01/12/14-20:01
fileXfer v175 (Release) 01/07/11-21:48
sensor v262 (Release) 02/05/08-17:28
Bronze
Ok, I actualy looked on a sensor this time, and the file is indeed missing. There appears to be a bug in the NSDB merge process during the installation of a signature update. For the time being, you should be able to view the NSDB pages from one of the mgmt. platforms (IEV, CSPM, UNIX Director). We should have this fixed in the S28 signature update. Thanks for the feedback.
I too am having this issue. Is there a way I can download the current NSDB? We do not have any of the management stations, and thus cannot access it.
Thank you
Ron Russell
rrussell@calence.com
Bronze
Should be able to access the full NSDB via IEV if you have installed it. Try this first. If this is not possible, you can download the CSPM signature update from CCO. This is simple a ZIP archive that contains the full NSDB also.
134
