3DES
I have a PIX 515 UR...even after having a UR why is the 3DES in the Show ver showing as Disabled?
Any ideas?
Thanks.
here is the output for sh ver
pixfirewall# sh ver
Cisco PIX Firewall Version 6.3(1)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Wed 19-Mar-03 11:49 by morlee
pixfirewall up 7 mins 57 secs
Hardware: PIX-515E, 64 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : IRE2141 with 2048KB, HW:1.0, CGXROM:1.9, FW:6.5
0: ethernet0: address is 000d.292b.7bdb, irq 10
1: ethernet1: address is 000d.292b.7bdc, irq 11
2: ethernet2: address is 00e0.b607.2e1b, irq 11
3: ethernet3: address is 00e0.b607.2e1a, irq 10
4: ethernet4: address is 00e0.b607.2e19, irq 9
5: ethernet5: address is 00e0.b607.2e18, irq 5
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Interfaces: 6
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has an Unrestricted (UR) license.
Serial Number: 807239581 (0x301d7f9d)
Running Activation Key: 0x91c1c7a1 0x908add32 0x551f7704 0xba193fb0
Configuration last modified by enable_15 at 01:08:14.876 UTC Sun Aug 24 2003
Gold
Re: 3DES
Try using the activation-key command for 6.3 code - But if you running 6.1 or below code then please check the following URL:
http://www.cisco.com/warp/public/110/upgrade.shtml
Hope this helps --
Re: 3DES
Hi thanks for your reply
Am runnin 6.3 code...and hve the activation-key command...So do i need to purchase a new activation key for 3DES to be enabled...i thought when i order for a UR i would be have 3DES...is'nt it ?
Do i have to pay for a new activation key or i can get it with CCO login id?
Pleas help
Raj Malhotra
Silver
Re: 3DES
3des used to be a separate software license - totally unrelated to UR vs. R license status. Cisco made it a free upgrade a few months ago.
https://www.cisco.com/pcgi-bin/Software/Crypto/crypto_main.pl?prod_refer=pix3des
that is the link. you need to fill that out, get an email from cisco. then use the activation key command, and reboot the pix at your leisure, and then strong crypto is yours
128
