4210 IDS not detecting small tcp port scans & windows null sessions
Perhaps someone can help me out and tell me if this is typical behavior for the 4210. I have been testing the device with the 3.1 software and have enabled all of the signatures in S40 and I can't seem to get it to detect small TCP connect scans (20-30 ports) to common services.
I tried some basic online scans from grc and symantec, etc. against our PIX interface with the IDS sniffer interface on a 10/100 hub in between. I cannot get it to fire an alarm for these scans. I also tried a tcp connect scan with fscan's default 300 or so ports and no alarm fired. I also cannot get it to detect a windows null session attempt, which the ids has a signature I enabled for that purpose. The only time I could get it to fire on a port scan was by doing a full 1-65535 nmap syn scan against the PIX interface.
Is there possibly something wrong with my setup, or do I need to tune something ???
thanks
Re: 4210 IDS not detecting small tcp port scans & windows null s
Update: I have determined there is definitely something wrong with my setup, as I was able to run these tests on another 4210 in production and they were detected, could be the 10/100 hub I'm using... we'll see
Definitely your hub, 10/100 mbit hubs have 2 backplanes for the different speed and the two are usually bridged together, if you have the firewall and the sensor on different segments you won't see anything.
129
