4506 port config for 515e
How should the port be configured for a connection to the 515e PIX?
1 REPLY
Hall of Fame Super Blue
Re: 4506 port config for 515e
If you are using layer vlan interfaces on your 4500 then just configure the port as a normal switchport and put it in the correct vlan. You should also be fine to turn on spanning-tree portfast provided you are not running the pix firewall in transparent mode.
If you are running 802.1q on the pix interface (ie logical interfaces) then you need to configure the port as a trunk.
Jon
100
