506E not able to go on the Internet. Help!!
I setup this PIX last week, tested it and worked fine. Now, when I plug it in everything on my internal network works fine. PIX is setup for dhcp, ok. When trying to access the internet, nothing.
I looked at the lights on the PIX (LINK is green, ACT is blinking on both interfaces) I am not sure what to do.
I am posting my config in case there is something I am not seeing.
PIX Version 6.1(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password Kgj8H0CArY1EQe85 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname PIX506E
domain-name XXXXXXX
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
pager lines 24
interface ethernet0 10full
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
<--- More --->
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.0.10 255.255.255.255 inside
pdm location 192.168.0.0 255.255.255.255 inside
pdm location 192.168.0.0 255.255.255.0 inside
pdm history enable
arp timeout 14400
global (outside) 1 216.73.XXX.XXX
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 216.39.XXX.XXX
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http 192.168.0.10 255.255.255.255 inside
snmp-server location
snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
<--- More --->
no sysopt route dnat
telnet 192.168.0.0 255.255.255.0 inside
telnet 192.168.0.10 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
dhcpd address 192.168.0.11-192.168.0.254 inside
dhcpd dns 216.73.XXX.XXX 216.73.XXX.XXX
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain inside
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:9be90af8f61c9d18b9e300237be8ef24
PIX506E#
I would appreciate any help that I can get..
Eduardo
Re: 506E not able to go on the Internet. Help!!
How are you trying to access the internet? Are you trying to ping? According to your configuration pings won't work, you need to allow icmp echo-replies specifically. Can you try browsing?
Hope this helps,
-Nairi
Hi Nairi,
I am just trying to browse. I dont want to ping. I tried this a few days ago and it worked just fine.
Any ideas would be greatly appreciated.
Eduardo
As a test can you change (ie remove your current global and then add the following) your global to:
global (outside) 1 interface
Then do a "clear xlate".
Does it work now?
Do a show log (as a side note add a syslog server to help you), show xlate, sh conn local/for x.x.x.x and see if anything is getting blocked and/or translated.
When the user tries to connect to a site, does DNS resolve the IP (if yes we can eliminate DNS)? Can the PIX ping any site, can the PIX ping the local hosts?
Hope it helps.
Steve
Steve,
You are a life saver... I tried what you told me and worked. What was wrong with what I had before???
Thanks again,
Eduardo
Glad it works. Your global IP (216.73.x.x) was different from your outside interfaces's subnet (216.39.x.x - based on your default route I assume that it is 216.39). So if you sent packets out with that IP, the return packets were not being routed to you as you don't own 216.73.x.x. As a side note I have noticed also that if you specify your outside IP in the global command it doesn't work, only using the keyword "interface" works.
Steve
Hi Eduardo,
Just some hints:
- I don't see the internal IP address apply to ethernet1
- Your default gateway is 216.39.x.y & your global is at 216.73.x.y which isn't in the same subnet ??? Generally, they are.
Ben
Hi Eduardo,
I can't find the "ip address" commands for you internal and external interface. You have to provide an ip for both the interfaces with the "ip address" command.
Kind Regards,
Tom
110
