10-10-2002 11:59 AM - edited 03-09-2019 12:37 AM
Lets say for example....my 515E config looks like such...
nameif ethernet1 inside security100
ip address inside 199.199.199.1 255.255.255.0
interface ethernet1 auto
static (inside,outside) 199.199.199.0 199.199.199.0 netmask 255.255.255.0 0 0
And I change it to this
ip address inside 200.200.200.1 255.255.255.0
static (inside,outside) 200.200.200.0 200.200.200.0 netmask 255.255.255.0 0 0
Basically just changing the static mappings and IP address of the internal interface. My questions is. Will this affect any of my rules. I do not think it will but I wanted to check.
Routing would have to change but other than that.
10-10-2002 01:11 PM
Your acls will have to change as well. If they reference the IP, you will need to remove the acl and re-apply with the new IPs. Other than routing and acls, you are good.
Hope it helps.
Steve
10-11-2002 04:25 AM
But if the acl looks like such why does it have to be touched
access-list acl_in permit tcp any 199.199.199.45 eq 22
and there is a new route for the 199.199.199.0 network to 200.200.200.0 then does it really matter the acl is just one more hop away
10-11-2002 10:17 AM
The static command creates a permanent mapping between a local IP address and a global IP address. Use the static and access-list commands when you are accessing an interface of a higher security level from an interface of a lower security level. It doesn't have anything to do with routing. Your 199.199.199.0 network is seen on the outside as 199.199.199.0, it's not being NAT'ed to a new IP. So if your acl is allowing access to 199.x.x.x but your static is 200.x.x.x, no one can access 200.x.x.x.
Steve
10-11-2002 10:38 AM
You are correct, Thanks for the input,
