5505ASA and Counterstrike
hello,
i run a game server and currenly client cannot connect. i can connect to the internet and the game server connects to the internet game managers, clients cannot connect to me. below is the running config, as you can see i have attempted to open the ports several times/ ways? still nothing! when i probe these ports with and outside tool, it is shown as 'stealth', i should have full opening here!
here is the config, please help me!
Saved
ASA Version 7.2(2)
hostname CISCO-ASA
domain-name DAVIDUMMEL.COM
enable password BQ3AMEy1YDiWi3f7 encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group verizon
ip address pppoe setroute
interface Vlan3
shutdown
no forward interface Vlan1
nameif dmz
security-level 50
no ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service STEAM_SERVER tcp-udp
description this is for connectivity to steam server
port-object range 27005 27050
access-list outside_access_in extended permit tcp any host 192.168.1.5 range 27005 27050
access-list outside_access_in extended permit udp any host 192.168.1.5 range 27005 27050
access-list outside_access_in extended permit tcp interface outside 192.168.1.0 255.255.255.0 range 27005 27050
access-list outside_access_in extended permit udp interface outside 192.168.1.0 255.255.255.0 range 27005 27050
access-list outside_access_in extended permit tcp any any range 27005 27050
access-list outside_access_in extended permit udp any any range 27005 27050
access-list inside_access_out extended permit tcp host 192.168.1.5 any range 27005 27050
access-list inside_access_out extended permit udp host 192.168.1.5 any range 27005 27050
access-list inside_access_out extended permit tcp 192.168.1.0 255.255.255.0 interface outside range 27005 27050
access-list inside_access_out extended permit udp 192.168.1.0 255.255.255.0 interface outside range 27005 27050
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group inside_access_out out interface inside
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group verizon request dialout pppoe
vpdn group verizon localname 1
vpdn group verizon ppp authentication pap
vpdn username 1 password ********* store-local
dhcpd auto_config outside
dhcpd address 192.168.1.100-192.168.1.200 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
i had to remove stuff for it to fit here
Re: 5505ASA and Counterstrike
does this shed any light?
log entries...
6 Jan 28 2007 19:37:18 302016 69.28.151.162 192.168.1.5 Teardown UDP connection 1696 for outside:69.28.151.162/27011 to inside:192.168.1.5/27015 duration 0:02:01 bytes 183
6 Jan 28 2007 19:35:45 302015 68.142.64.165 192.168.1.5 Built outbound UDP connection 1699 for outside:68.142.64.165/27014 (68.142.64.165/27014) to inside:192.168.1.5/26900 (71.177.125.89/1160)
6 Jan 28 2007 19:35:47 302014 65.193.119.140 192.168.1.3 Teardown TCP connection 1690 for outside:65.193.119.140/80 to inside:192.168.1.3/2459 duration 0:01:05 bytes 3216 TCP FINs
Counter-Strike (at least the 1.6 version) works
on port 27015/udp, dude.
120
