6509 FWSM Xlate conn problem
We have 6509 FWSM in which we have configure VLAN's for different customers but for one customer sometimes he cant able to access his remote location.Once we clear Xlate all then it works fine.Network set up is like this way .
HO -------------POP (6509 FWSM)----------Remote
We have create VLAN for this cust & route traffice on that VLAN.
Is any one facing same problem.
TIA
SAM
Silver
Re: 6509 FWSM Xlate conn problem
When memory usage exceeds 90%, the clear xlate command may cause an unexpected FWSM reload.
I beleive you are running into resource limitation issues. If you are running the FWSM in mutiple-context mode please make sure that the customer has enough possible resources for normal operation. Just before you do a clear xlate try the following commands to get a better idea
show resource allocation detail
show resource usage detail
and look for the specific context
535
