6513 MODE
How to see the native, hybrid mode in 6513 using sh command
  • Other Security Subjects
Re: 6513 MODE
Hello aksher@cisco,
Type "show ver". Anything that starts with 12.1E or 12.2SX is native. Anything that starts with 5.1-8.5 is hybrid mode.
Also, if you spend a little time on 2 switches (1 running native, the other hybrid), it is quite apparent what mode the switch is running.
A "show ver" from a Native switch
Router# show version
IOS (tm) c6sup2_rp Software (c6sup2_rp-JSV-M), Version 12.1(nightly.E020626) NIG
HTLY BUILD
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 26-Jun-02 06:20 by
Image text-base: 0x40008BF0, data-base: 0x419BA000
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
Router uptime is 2 weeks, 8 hours, 48 minutes
Time since Router switched to active is 1 minute
System returned to ROM by power-on (SP by power-on)
System image file is "sup-bootflash:c6sup22-jsv-mz"
cisco Catalyst 6000 (R7000) processor with 112640K/18432K bytes of memory.
Processor board ID SAD06210067
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
3 Virtual Ethernet/IEEE 802.3 interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 512K).
Router#
A "show ver" from a Hybrid switch
Console> show version
WS-C6009 Software, Version NmpSW: 6.2(0.11)KEY
Copyright (c) 1995-2000 by Cisco Systems
NMP S/W compiled on Oct 5 2000, 01:18:33
System Bootstrap Version: 5.2(1)
Hardware Version: 1.0 Model: WS-C6009 Serial #: SCA030900JA
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP1A-2GE SAD03392376 Hw : 1.0
Fw : 5.2(1)
Fw1: 5.1(1)CSX
Sw : 6.2(0.11)KEY
Sw1: 6.2(0.11)KEY
L3 Switching Engine SAD03365068 Hw: 1.0
3 2 WS-X6380-NAM JAB0343055Y Hw : 0.201
Fw : 4B4LZ0XA
Fw1: 4.2(0.24)DAY68
Sw : 1.1(0.20)
Sw1: 6.2(0.11)KEY
5 48 WS-X6248-RJ-45 SAD03181291 Hw : 1.0
Fw : 4.2(0.24)VAI78
Sw : 6.2(0.11)KEY
15 1 WS-F6K-MSFC SAD03366264 Hw : 1.2
Fw : 12.1(2)E,
Sw : 12.1(2)E,
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65408K 45402K 20006K 16384K 8683K 7701K 512K 253K 259K
Uptime is 1 day, 19 hours, 54 minutes
Console> (enable)
Hope that helps! If so, please rate.
Re: 6513 MODE
how to switchover between these two modes.
Re: 6513 MODE
Hello aksher@cisco,
This is not a trivial task. Here are links for both conversions.
System Software Conversion from CatOS to Cisco IOS for Catalyst 6500/6000 Switches
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml
System Software Conversion from Cisco IOS to CatOS for Catalyst 6500/6000 Switches
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801350b8.shtml
Re: 6513 MODE
i had meant on how to switchover to different modes in FWSM and the corresponding changes that needs to be done on FWSM.you have asked to change CatOS to IOS
Re: 6513 MODE
Actually you asked "How to see the native, hybrid mode in 6513 using sh command" That is why I posted what I posted. I saw you posted another message asking about transparent mode. I too sent you a link there with instructions on what needs to be done. Hope that helps!
339
