6to4 tunneling issues
I have the following setup:
PC---fa0/0-Router1-fa0/1----fa0/0-Router2-fa0/1---PC
and am trying to get 6to4 tunnels happening between the two routers but
to no avail. I believe its something in the route in place but for the
life of me I cant spot the error, as the error I get when I try to ping
from a PC to the non-directly attached router I get "request timed out"
errors
It might be a tunnel problem as the destination comes up as "UNKNOWN"
Can someone please help!!! Ive got GRE tunneling and manual tunnels
working, but need to test this config (6to4 tunnels) as well.
Attached file shows the configs, the IPv6 routes, and the show Interface Tunnel 0 command. Router configs are as below :
Router1#sh run
version 12.3
hostname Router1
boot-start-marker
boot-end-marker
memory-size iomem 10
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
ipv6 unicast-routing
interface Tunnel0
no ip address
no ip redirects
ipv6 address 2002:C0A8:6301::1/64
tunnel source FastEthernet0/1
tunnel mode ipv6ip 6to4
interface FastEthernet0/0
no ip address
duplex auto
speed auto
ipv6 address 2002:C0A8:6301:1::1/64
ipv6 enable
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
ip address 192.168.99.1 255.255.255.0
duplex auto
speed auto
ipv6 enable
interface Serial0/1
no ip address
shutdown
ip http server
no ip http secure-server
ip classless
ipv6 route 2002::/16 Tunnel0
line con 0
line aux 0
line vty 0 4
end
Router2#sh run
version 12.3
hostname Router2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
interface Tunnel0
no ip address
no ip redirects
ipv6 address 2002:C0A8:2101::1/64
tunnel source FastEthernet0/0
ip address 192.168.33.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface BRI0/0
no ip address
shutdown
no ip address
duplex auto
speed auto
ipv6 address 2002:C0A8:2101:1::1/64
ipv6 enable
interface Serial0/1
no ip address
shutdown
ip http server
ip classless
line con 0
line aux 0
line vty 0 4
end
1 REPLY
Silver
Re: 6to4 tunneling issues
The issue may be due to redistribution or due to NAT.
For configuring NAT follow these steps.
1. enable
2. configure {terminal | memory | network}
3. ipv6 nat v4v6 source ipv6-address ipv4-address
or
ipv6 nat v4v6 source {list access-list-name | route-map map-name} pool name
4. ipv6 nat v6v4 pool name start-ipv4 end-ipv4 prefix-length prefix-length
5. ipv6 nat translation [max-entries number] {timeout | udp-timeout | dns-timeout | tcp-timeout | finrst-timeout | icmp-timeout} {seconds | never}
6. ipv6 access-list access-list-name
7. permit {protocol} {source-ipv6-prefix/prefix-length | any | host source-ipv6-address} [operator [port-number]] {destination-ipv6-prefix/prefix-length | any | host destination-ipv6-address}
8. exit
9. show ipv6 nat translations [icmp | tcp | udp] [verbose]
10. show ipv6 nat statistics
289
