09-19-2005 11:48 AM - edited 02-20-2020 09:28 PM
I'm performing a NAT translation on a Linksys router that is attached to fa1/0 on my 7206. I want to only allow HTTP,SSL and DNS traffic out of fa1/0 from the Linksys. I have put in place an ACL to allow this traffic flow but it seems to skip over the acls I put in place and only hits the permit ip any any. If I try to use the address of the Linksys router in my ACL's it doesn't work. If I try: any any eq www that doesn't work either. So I assume Cisco ACLs are not liking how the address is translated by the Linksys router. Any thoughts?? Below is the acl in question:
10 permit tcp any host ###.###.###.### eq domain
20 permit udp any host ###.###.###.### eq domain
30 permit tcp any any eq www
40 permit tcp any any eq 443
50 permit ip host ###.###.###.### any
60 deny ip any any (7 matches)
Here is the port config fa1/0:
interface FastEthernet1/0
ip address ###.###.###.### 255.255.255.252
ip access-group inet-edge-wireless out
no ip redirects
no ip unreachables
no ip proxy-arp
duplex full
speed 100
09-19-2005 04:50 PM
Perhaps the ACL needs to be applied inbound, or else reverse the source and destination ports. Your ACL statements will match packets from the client to the server. If you want to match from the server to the client they need to look like this:
30 permit tcp any eq www any
09-20-2005 04:39 AM
The interface definition looks OK.
Can you add log to the last element of the ACL and then post the log output? This should show the src/dst IP addresses and the ports.
I am assuming that the ###.###.###.### in the DNS rules is the address of your remote DNS server.
Kind Regards
Cathy
09-20-2005 12:35 PM
I figured it out. Out vs In....its all a matter of perspective. I was assigning it outbound and it needed to be assigned inbound. I assumed data flowing from my internal network to the port was outbound but apparently not (according to Cisco's ACL rules). Perspective, perspective!!!! Thanks for the help!
Nick
