05-20-2002 10:01 PM - edited 02-21-2020 11:45 AM
Has anyone gotten both the 827 router to support both Lan-to-Lan tunnel to
a VPN 3030 concentrator and supporting VPN 3.5 client? I am able to
get either the lan-to-lan tunnel or VPN 3.5 client to connect. However,
if the lan-to-lan tunnel is established, the VPN 3.5 clients are not able to
to connect, vice versa. Can't seem to get both of them to work at the same time.
Appreciate any help on this.
P
05-21-2002 04:38 AM
Make sure that you are following the following document on CCO
http://www.cisco.com/warp/public/471/ipsecrouter_vpn.html
Jazib
05-21-2002 06:35 AM
Thanks Jazib,
I will give it a try!
