871W VPN SSID Question
I'm going to setup ezvpn tunnel between 871w router to concentrator 3005.
I also want to create 2 WLAN (ssid) on the 871W. One ssid that goes thru the tunnel (that will be my corporate ssid) and the other ssid (guest) will access only the internet.
Can this be done and if so can I have an example (use any ip's)
Re: 871W VPN SSID Question
Did you ever figure this out? We're trying to do the same thing.
Yes are you using an 871w router ?
Yes.
113
