A few basic questions on CAS
Dear friends,
I am using CAS server 4.7.2.
1. A user was earlier reporting that she was getting prompted for clean access login again and again.
By the time, i went, the problem was resolved.
I checked the perfig-log under /perfigo/logs folder but it did not show any indication.
Is there any other place that i should be looking for at the problem time.
2. Also, i am getting the following error in perfigo-log. Is it common to get this error and is it informational only?
Using JRE_HOME: /usr/java/jdk1.6.0_12
[FAILED]
3. Is there any way to enable verbose logging for NAC client so that we know when he is connecting, disconnecting and so on?
Thanks a lot
Gautam
Re: A few basic questions on CAS
Gautam,
Wrong place! In 4.7 look for logs under /perfigo/access/tomcat/logs
Faisal
"A user was earlier reporting that she was getting prompted for clean access login again and again"
I recommend that you check manage subnet and vlan mapping at the CAS the problem could be located at that level.
Juan Huicab Internetworking juan.huicab@nextiraone.com.mx T 52 (81) 1001 8000 E 8015 C 52 (81) 1077 2435 San Pedro Garza García, N. L. México www.nextiraone.com.mx
Also if that client is behind a IP Phone you have to verify the
filter list in order to check if that device is include.
196
