a mind boggler
lee
Thanks in advance.
there has to be a reason for this. I am unable to get authenticated on pipex radius server although i am continually hitting their server. pipex are informing me that i am dialing in then disconnecting and repeating this continously until the radius server blocks me out and then i get blocked by a what i believe to be a bt router. pipex tell me im dialling in every two to three seconds ( 40 times over two minutes they told me) but obviously not authenticating.
i did authenticate a couple of times yesterday, but dropped almost immediately.
im running cisco 1720 adsl.
ive pasted config and chall/response.
please help im baffled
n.b. could there be a software bug or patch
ive logged on no problem using my dsl modem at home with the user id and password.
PP authentication debugging is on
******@xtreme.pipex.net#
01:42:52: Vi1 CHAP: O CHALLENGE id 237 len 44 from "****@xtreme.pipex.net"
01:42:52: Vi1 CHAP: I CHALLENGE id 212 len 39 from "sms1.dsl.pipex.net"
01:42:52: Vi1 CHAP: Username sms1.dsl.pipex.net not found
01:42:52: Vi1 CHAP: Unable to authenticate for peer
01:42:56: Vi1 CHAP: O CHALLENGE id 238 len 44 from "<A HREF="mailto:******@xtreme.pipex.net">******@xtreme.pipex.net</A>"
01:42:56: Vi1 CHAP: I CHALLENGE id 213 len 39 from "sms1.dsl.pipex.net"
01:42:56: Vi1 CHAP: Username sms1.dsl.pipex.net not found
01:42:56: Vi1 CHAP: Unable to authenticate for peer
01:43:00: Vi1 CHAP: O CHALLENGE id 239 len 44 from "******@xtreme.pipex.net"
01:43:00: Vi1 CHAP: I CHALLENGE id 214 len 39 from "sms1.dsl.pipex.net"
01:43:00: Vi1 CHAP: Username sms1.dsl.pipex.net not found
01:43:00: Vi1 CHAP: Unable to authenticate for peer
01:43:04: Vi1 CHAP: O CHALLENGE id 240 len 44 from "******@xtreme.pipex.net"
01:43:04: Vi1 CHAP: I CHALLENGE id 215 len 39 from "sms1.dsl.pipex.net"
01:43:04: Vi1 CHAP: Username sms1.dsl.pipex.net not found
01:43:04: Vi1 CHAP: Unable to authenticate for peer
01:43:08: Vi1 CHAP: O CHALLENGE id 241 len 44 from "******@xtreme.pipex.net"
01:43:08: Vi1 CHAP: I CHALLENGE id 216 len 39 from "sms1.dsl.pipex.net"
01:43:08: Vi1 CHAP: Username sms1.dsl.pipex.net not found
01:43:08: Vi1 CHAP: Unable to authenticate for peern
01:43:12: Vi1 CHAP: O CHALLENGE id 242 len 44 from "******@xtreme.pipex.net"
01:43:12: Vi1 CHAP: I CHALLENGE id 217 len 39 from "sms1.dsl.pipex.net"
01:43:12: Vi1 CHAP: Username sms1.dsl.pipex.net not found
01:43:12: Vi1 CHAP: Unable to authenticate for peero debug all
All possible debugging has been turned off
01:43:16: Vi1 CHAP: O CHALLENGE id 243 len 44 from "******@xtreme.pipex.net"
01:43:16: Vi1 CHAP: I CHALLENGE id 218 len 39 from "sms1.dsl.pipex.net"
01:43:16: Vi1 CHAP: Username sms1.dsl.pipex.net not found
01:43:16: Vi1 CHAP: Unable to authenticate for peer
******@xtreme.pipex.net#show run
Building configuration...
Current configuration : 2586 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ******@xtreme.pipex.net
logging rate-limit console 10 except errors
enable secret 5 $1$d6OJ$JU.yzY/g6lGebq0i.gD5H0
username *****password 7 1303120602051C2F31
username *****@xtreme.pipex.net password 7 09474F1D1801181D11
username ******@xtreme.pipex.net password 7 0827494800101D1208
memory-size iomem 25
ip subnet-zero
no ip source-route
no ip finger
ip dhcp excluded-address 192.168.1.2
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.254
ip dhcp excluded-address 192.168.1.3
ip dhcp excluded-address 192.168.1.4
ip dhcp excluded-address 192.168.1.5
ip dhcp excluded-address 192.168.1.6
ip dhcp excluded-address 192.168.1.7
ip dhcp excluded-address 192.168.1.8
ip dhcp excluded-address 192.168.1.9
ip dhcp pool hertford
network 192.168.1.0 255.255.255.0
dns-server 158.43.240.4 158.43.240.3
default-router 192.168.1.254
no ip dhcp-client network-discovery
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key ***** address 52.168.35.118
crypto ipsec transform-set strong esp-3des esp-sha-hmac
crypto map vpn 10 ipsec-isakmp
set peer 52.168.35.118
set transform-set strong
match address 101
interface ATM0
no ip address
ip nat outside
atm vc-per-vp 256
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
no fair-queue
crypto map vpn
interface FastEthernet0
ip address 192.168.1.254 255.255.255.0
ip nat inside
speed auto
no cdp enable
interface Dialer0
ip address 52.168.35.126 255.255.255.248
ip access-group 150 in
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication chap
crypto map vpn
ip nat pool vpn 52.168.35.121 52.168.35.121 prefix-length 29
ip nat inside source list 10 pool vpn overload
ip nat inside source static 192.168.1.2 52.168.35.122
ip nat outside source static 52.168.35.122 192.168.1.2
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
access-list 10 deny 192.168.1.2
access-list 10 permit 192.168.1.0 0.0.0.255
access-list 101 permit ip host 52.168.35.122 host 52.168.35.113
access-list 150 permit ip 52.168.35.112 0.0.0.7 52.168.35.120 0.0.0.7
access-list 150 permit tcp any any established
no cdp run
line con 0
password 7 045219561E34495A01
login
transport input none
line aux 0
password 7 020F160B1A130A3544
login
line vty 0 4
login
end
cjacinto
Looks like you are also trying to authenticate your peer, have you tried ppp authentication chap callin under the dialer 0 so you don't
authenticate your isp?
