A question in regards to PPTP using virtual-templates and routing problems
Hi.
A little information before I ask a question. My config is below...
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
interface Virtual-Template1
ip unnumbered Loopback0
peer default ip address pool vpdn
compress mppc ignore-pfc
ppp encrypt mppe 40 passive
ppp authentication ms-chap
The PPTP Tunnel works like a champ. The issue I have is that the routes get messed up when the PPTP tunnel is up. Whenever I have the tunnel up internally, the PPTP connection wants everything passed through it. This means that even though I have a default route for my internal network, the PPTP tunnel causes it not to work. I have tried various fixes, one is below. Which didn't work....
ip route 0.0.0.0 0.0.0.0 Fa0/1
ip route ip.ip.ip.ip 255.255.255.0 virtual-template 1
All traffic still wants to go through only the virtual-template 1 interface. I have tried messing around with using various route statements. None of
them have worked.
Maybe I am incorrect in assuming that the VT interface should not be treated the same as a tunnel interface. (or any other interface for that matter)
Another footnote would be that I went through about 5 IOS versions to get PPTP to work properly.
I am currently running 12.1(5)T6
Any input will be appreciated.
1 REPLY
Re: A question in regards to PPTP using virtual-templates and ro
Ok.
I am guilty of not browsing the board before asking a previously answered question.
I also had a brain freeze since the tunnel is established between the client and the remote router, so this means the local router could care less due to the fact that the client already has a route it wants to use...
Sorry. :)
BTW: The answer is to not use the default gateway of the remote system. This is check box under tcp/ip settings under the network settings of the Windows PPTP client.
This is depressing since I chose an inappropriate logic with changing the light switch, before checking the bulb. *cough*
207
