Community Member
a way to avoid fully meshed VPNs ?
Does anyone know if its's possible to configure for instance 3 firewalls so that two remote offices that only have VPN tunnels to the firewall at headguarters can access each others networks ?
So what I really want to know if their is a way to avoid fully meshed VPN's and let remote VPN's only connect to HQ where they must be routed back into one of the other VPN tunnels.
1 REPLY
Community Member
Re: a way to avoid fully meshed VPNs ?
If you are using the cisco pix firewall that's not possible because the pix can't route traffic to the same interface on which the traffic has been received.
But if you're using Cisco IOS with firewall feature Set you can implement that by using tunnel endpoint discovery.
Hope that helps ;-)
Michael
ERNW Germany
208
