Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Abnormal console display when IPSec/Isakmp debug is on
IE_R1#sh debugging
Cryptographic Subsystem:
Crypto ISAKMP debugging is on
Crypto IPSEC debugging is on
IE_R1#
1d03h:
IPSEC(encapsulate): encaps area too small, moving to new buffer: idbtype 0, encaps_size 84, header size 36, avail 84
IPSec works fine in my case, but the console frequently
shows the above annoying messages. NIL normal debug messages
for IPSec. Could any body help?
If I disabled all debug processes, everything is OK.
Bruce IP Hung-kwong
1 REPLY
Silver
Re: Abnormal console display when IPSec/Isakmp debug is on
This is a known issue when you run IPSec on ethernet interfaces while running on IOS 12.2(11)T. This issue should be resolved in the later version of code, 12.2(13)T or alternatively, you can downgrade to 12.2(8)T5.
100
