Accesing PDM from outside with VPN Client
My goal is to access PDM GUI from outside.
I'm using VPN client 3.0 and I have configured PIX and VPN client with IKE mode config and Xauth. I did not have problems for permitiing telnet access to PIX from outside, that is easy. But, I can not connect to the PDM GUI. Can anyone help me?
Bronze
Re: Accesing PDM from outside with VPN Client
If you can telnet to the PIX’s inside interface across your tunnel, you should be able to browse to it. Can you from inside? Are you sure you’re entering HTTPS:// (not HTTP://). I haven’t tested or tried it though from outside through a VPN tunnel.
Yes, I have tried from inside, works fine, but from outside nothing yet. And yes, I'm using https://
wan
The PDM needs to be defined by IP address. Try creating an address pool of a single address for the VPN connection and grant that IP address access.
279
