Community Member
Access Control Question
I want to be able to set a Client up to be able to telnet into a 2950 Switch and be able to do only interface level configuring on a switchport. I do not want them to have conifig privilages. I looked on CCO and all it says is to give that level of access spacific commands that it can do but I can get it to work. Is this possible?
Any help would be appreciated. Thanks
Here's what I did:
enable password level 2 cisco
privilege exec level 2 config
privilege interface level 2 interface fast ethernet
privilege interface level 2 speed
privilege interface level 2 duplex
privilege interface level 2 shut
privilege interface level 2 no shut
1 REPLY
Community Member
Re: Access Control Question
You are on target, and the following document verifies it:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/1219ea1/scg/swadmin.htm#xtocid8
Be aware there have been a few bugs associated with custom privilege levels, CSCdt04001 being one of the more profound ones. Ensure you aren't running into something like this.
83
