access list problem
I'm trying to solve a strange issue with a PIX 506
The PIX is configured to separate two internal networks 192.168.20.0 ( outside interface ) 192.168.5.0 ( inside interface ) .
hosts on the outside should only be permitted icmp,udp,tcp traffic to a remote host (REPLICA 192.168.1.x) which is reachable through a router on the inside interface.
The configuration is the following
name 192.168.1.4 REPLICA
name 172.16.1.0 NET-RADIO
access-list outside_access_in permit tcp 192.168.20.0 255.255.255.0 host REPLICA log 4
access-list outside_access_in permit icmp 192.168.20.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list outside_access_in permit icmp 192.168.20.0 255.255.255.0 192.168.5.0 255.255.255.0
access-list outside_access_in permit udp 192.168.20.0 255.255.255.0 host REPLICA log 4
access-list inside_access_in permit ip 192.168.1.0 255.255.255.0 any log
access-list inside_access_in permit ip 192.168.5.0 255.255.255.0 any
access-list inside_access_in permit icmp 192.168.1.0 255.255.255.0 any
access-list inside_access_in permit icmp 192.168.5.0 255.255.255.0 any log 4
ip address outside 192.168.20.253 255.255.255.0
ip address inside 192.168.5.253 255.255.255.0
nat (inside) 0 192.168.1.0 255.255.255.0 0 0
nat (inside) 0 192.168.5.0 255.255.255.0 0 0
static (outside,inside) 192.168.20.0 192.168.20.0 netmask 255.255.255.0 0 0
static (inside,outside) 192.168.5.254 192.168.5.254 netmask 255.255.255.255 0 0
static (inside,outside) 192.168.1.253 192.168.1.253 netmask 255.255.255.255 0 0
static (inside,outside) NET-RADIO NET-RADIO netmask 255.255.255.248 0 0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route inside NET-RADIO 255.255.255.248 192.168.5.253 1
route inside 192.168.1.0 255.255.255.0 192.168.5.253 1
icmp permit any outside
icmp permit any inside
The problem is that the traffic gets blocked and in the log we found the following
305005: No translation group found for icmp src outside:192.168.20.98 dst inside:REPLICA (type 8, code 0)
1 REPLY
Silver
Re: access list problem
This makes no sense - statics should reference high security ints, then low security ints.
static (inside, outside) 192.168.5.0 192.168.5.0 netmask 255.255.255.0
would statically map the inside subnet for outside access - commonly seen in environments where nat is not used
You do not have a static command for replica - all of the other static commands are for 3 other hosts -
Create a static for replica.
99
