12-22-2003 06:25 AM - edited 03-09-2019 05:57 AM
When trying to access the web server on the DMZ, all internal addresses go the the outside connection and use the outside IP address instead of going straight to the DMZ using the address on the DMZ. The browser is not able to find the real IP address of the web server. This has been intermitant, but now is constant. What can we put on our Pix 515 to go straight to the web server on the DMZ?
12-22-2003 06:40 AM
Hi -
Have you got a static statement like the example below on you PIX config:
static (inside,dmz) 192.168.5.0 192.168.5.0 netmask 255.255.255.0
Remember to issue cmd clear xlate and save with write memory.
Jay.
12-22-2003 06:59 AM
Yes, that statement is there.
12-22-2003 07:54 AM
Okay, can you post your PIX config pls, either here on the forum or direct to myself at : jmia@ohgroup.co.uk
Pls remember to change real IPs and passwords etc.
Thanks - Jay.
