accessing html interface of acs
wanglei
when i use web access acs.the login page appears,i don't know what username should i
input,
where can i generate this username?
which step can i generate this username,if it's during the install step?
or it is a default name like pix to access pix?
thank you very much for help.
thomas.chen
Level 6
Level 6
To connect to the CiscoSecure ACS HTML interface from a LAN or dial-up connection, you must enter a username and password in the CiscoSecure Administration Control window. To access the interface remotely (from a machine other than the local Windows NT Server) you must configure an administrator's username and password in the Administration Control window of the HTML interface.
