Accessing to PDM in read-only mode
Hi all.
I have a Pix with ver 6.3 and I want to enable an access to it for the Customer in a read-only mode.
I ordinarily don't use aaa and privileges to avoid lock-out problems but now it seems I must face the topic.
I have 2 questions:
A. Is the following plan safe (and sufficient) to avoid lockout?
1. username admin password **** priv 15
2. username pdmuser password **** priv 5
3. aaa authentication http console LOCAL
4. privilege level 5 command ???
B. Which commands shoul I assign to privilege level 5 to let the user see the Home and the Monitoring Page completely?
Thank you
michele
1 ACCEPTED SOLUTION
Silver
Re: Accessing to PDM in read-only mode
Hi Michele,
A. Yes, it is safe and sufficient not to lock out of the pix. Infact, your telnet/console will not be affected, only the PDM with the above config in place.
B. There are three different priv levels for PDM, Monitor (level 3), Read Only (level5) and admin (level 15). So, Monitor level is all it requires to get access to the Home Page and Monitoring page. Here is the procedure:
Turning on AAA for PDM:
-System properties
-Pix Admin
-Authentication/Authorization
-check HTTP/PDM box
-service group select LOCAL
-Check ENBALE AUTHORIZATION box
Creatting Users:
-User account -> user with level 15 and 3 (monitor)
Mynul.
1 REPLY
Silver
Hi Michele,
-System properties
-Pix Admin
-check HTTP/PDM box
Creatting Users:
Mynul.
117
