Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
ACL doesn't work with Client 3.x
i am useing a cisco 2621 router to be a easy vpn server
and now planning to let net 192.168.0.0/24 to encryption between client and server
so i have the acl like
access-list 180 permit 192.168.0.0 0.0.255.255
and the assign to the crypto isakmp client configuration group
then i dial the vpn client to server, and the network is appear in the statistics window, but it seem that there's no any encrypted transfer between the client and the server , and i notice that there is no a yellow little lock left to the network entry,
Anybody meet the the same problem?
and how can i solve it?
Thanks and Regrads,
Wells Wei
Re: ACL doesn't work with Client 3.x
So 192.168.0.0/24 is the inside network right? What is the ip address pool you give to your client? The acl to enable split tunnelling (which falls under
the group) is of the format:
acl
or you could also use any keyword instead of the vpn client pool.
See:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t8/ftunity.htm#xtocid24
You would also want to enable the log viewer (filter set to high) on the client to
see what you are getting when you have tried to connect to the router. Router debugs and config you could compare from:
http://www.cisco.com/warp/customer/471/ios-unity.html
Thank you for ur answer...
i have the client pool 172.30.1.0/24
and i have try to make my acl like access 180 permit ip 192.168.0.0 0.0.255.255 172.30.1.0 0.0.0.255
but i still doesn't work!
the little key still not appear left to the ip subnet range in the vpn client
and my client version is 3.5.2A
u know what happen ? thank you!
83
