ACL Help
I have been given a template to use to configure our Internet router sitting outside our firewall.
I have done the test using the template and found out that our Internet mail cant go through. Our mail server cant communicate with other mail servers outside the internet. Below is the tempplate. We just want internet traffic and mail traffic to go through the router.
Can somebody help me
This is designed for simple 2 interface routers with only a single Live IP subnet range.
Created in accordence with SANS recommendations
Reference rr.sans.org/netdevices/cisco_gear.php
Variables - These require replacement with correct values.
Telnet Approved Networks a.a.a.a b.b.b.b
Live Exernal IP's c.c.c.c d.d.d.d
SNMP Approved Networks g.g.g.g h.h.h.h
Interface Name: INTERNAL INTERFACE
Interface Name: EXTERNAL INTERFACE
SNMP RO Community: changethis
!ROUTER CONFIGURATION
service password-encryption
banner login #
* This is a private system *
* Access to this computer system is limited to authorised users only. *
* This authorization must be obtained in writing from the system owner *
* Unauthorised users may be subject to prosecution under the Crimes *
* Act or State legislation *
* All accesses to this service are logged *
* All information and details on this system are private, *
* confidential and must not be disclosed *
no service finger
no ip bootp server
no ip http server
no service udp-small-servers
no service tcp-small-servers
no service config
no service pad
no service dhcp
no service ntp
no tftp-server
no ip identd
no snmp-server
no cdp run
service tcp-keepalives-in
no ip domain-lookup
no ip source-route
ip subnet-zero
ip classless
!This will affect some services
interface INTERNAL INTERFACE
description Internal Interface
no ip redirects
no ip unreachables
no ip directed-broadcast
no ip proxy-arp
no ip mroute-cache
no cdp enable
no ip mask-reply
interface EXTERNAL INTERFACE
description External Interface
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
no cdp enable
no ip mask-reply
!Ingress Filtering
ip access-list extended ingress-filter
deny ip host 0.0.0.0 any log
deny ip 10.0.0.0 0.255.255.255 any log
deny ip 127.0.0.0 0.255.255.255 any log
deny ip 169.254.0.0 0.0.255.255 any log
deny ip 172.16.0.0 0.15.255.255 any log
deny ip 192.168.0.0 0.0.255.255 any log
deny ip 192.0.2.0 0.0.0.255 any log
deny ip 224.0.0.0 15.255.255.255 any log
deny ip 240.0.0.0 7.255.255.255 any log
deny ip 248.0.0.0 7.255.255.255 any log
deny ip host 255.255.255.255 any log
permit icmp any c.c.c.c d.d.d.d packet-too-big
permit icmp any c.c.c.c d.d.d.d echo-reply
permit icmp any c.c.c.c d.d.d.d ttl-exceeded
permit icmp any c.c.c.c d.d.d.d source-quench
permit icmp c.c.c.c d.d.d.d echo
deny icmp any any
deny ip c.c.c.c d.d.d.d any log
permit ip any c.c.c.c d.d.d.d
deny udp any range 1 65535 any log
deny tcp any range 1 65535 any log
deny ip any any log
int EXTERNAL INTERFACE
ip access-group ingress-filter in
ip accounting access-violations
int INTERNAL INTERFACE
ip access-group ingress-filter out
!Egress Filtering
ip access-list extended egress-filter
permit icmp c.c.c.c d.d.d.d any packet-too-big
permit icmp c.c.c.c d.d.d.d any echo
permit icmp c.c.c.c d.d.d.d any ttl-exceeded
permit icmp c.c.c.c d.d.d.d any source-quench
permit icmp c.c.c.c d.d.d.d echo-reply
deny icmp any any
permit ip c.c.c.c d.d.d.d any
deny ip any any log
ip access-group outbound-filter in
ip access-group outbound-filter out
!Logging Configuration
logging buffered 32768 informational
no logging console
service timestamps log datetime msec localtime show-timezone
service timestamps debug datetime msec localtime show-timezone
clock timezone GMT +10
access-list 99 permit a.a.a.a b.b.b.b log
access-list 99 deny any log
line vty 0 4
access-class 99 in
exec-timeout 15 0
login
transport input telnet
line aux 0
no exec
exec-timeout 0 10
transport input none
1 REPLY
Silver
Re: ACL Help
Check if you have opened the mail service port on the Firewall. If not open the SMTP port 25 on the firewall.
179
