Community Member
ACL Help
I am using Subnet 172.18.100.0 Mask 255.255.252.0. My Manager has sent me a list and ask to implement the same. pls help me what IP and mask should I use. List is as below :
1. Block DNS zone transfer access-list 101 deny tcp any any eq domain log-input
2. Allow DNS response access-list 101 permit udp any eq domain < ip address> <Subnetmask>
3. Block packets that are sourced from reserved private addresses
Block loopback packets
4. access-list 101 deny ip < ip address> <Subnetmask> any log-input
Block multicast packets
5. access-list 101 deny ip < ip address> <Subnetmask> any log-input
Block broadcast
6. -list 101 deny ip 0.0.0.0 0.255.255.255 any log-input
Pls help as per my Subnet and Mask.
Anis
Purple
Re: ACL Help
Hi Anis,
Use 172.18.100.0 and wildcard mask 0.0.3.255
Hope that helps - pls rate posts that help.
Paresh
Re: ACL Help
The first question would be where you apply the access-list - inbound or outbound. Because then respectively source and destination have to be swapped. The following statements should be helpful for an inbound access-list from the rest of the world to 172.18.100.0/22:
1.
access-list 101 deny tcp any eq domain any log-input
2.
access-list 101 permit udp any eq domain 172.18.100.0 0.0.3.255
3. somewhat unclear what "Loopback" means, I assume 127/8
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
4.
access-list 101 deny ip 224.0.0.0 15.255.255.255 any
access-list 101 deny ip any 224.0.0.0 15.255.255.255
5. what is meant by "broadcast"? a router will stop broadcast anyhow.
6. as above.
Hope this helps! Please rate all posts.
Regards, Martin
219
