ACL Issue.
Hello all, for some reason with this packet tracer lab I keep getting the last bit of ACL's incorrect.
Here is the lab that I have completed so far (94%)
http://www.sendspace.com/file/gsnk07
They ask me the following
Configure standard named ACLs on the R1 and R3 vty lines, permitting hosts connected directly to their Fast Ethernet subnets to gain Telnet access. Explicitly deny all other connection attempts.Name these standard ACLs VTY-Local.
They also ask this for the extended ACL's
Name the ACL block.
Prohibit traffic originating from the R1 LAN from reaching the R3 LAN.
Prohibit traffic originating from the R3 LAN from reaching the R1 LAN.
Permit all other traffic.
Here is what I have on router 1 for the standard ACLs
ip access-list standard VTY-Local
deny 10.1.0.0 0.0.0.3
deny 10.3.0.0 0.0.0.3
deny 10.3.1.0 0.0.0.255
permit 10.1.1.1 0.0.0.255
I could not figure out why my ACL's are incorrect.
Host 1's IP (The host connected to R1 ip) - 10.1.1.1
Serial connection from R1 to R2 ip subnet is
10.1.0.0 /30
R2 to R3 is
10.3.0.0 / 30
Host 2 to R2
10.3.1.0 /24
Host 2's address is 10.3.1.1 /24
Can someone help me?
1 ACCEPTED SOLUTION
Re: ACL Issue.
deny 10.1.0.0 0.0.0.3 - matches IP 10.1.0.x
deny 10.3.0.0 0.0.0.3 - matches IP 10.3.0.x
deny 10.3.1.0 0.0.0.255 - matches IP 10.3.1.x
permit 10.1.1.1 0.0.0.255 - match IP 10.1.1.0
Correct ACL's should be:-
permit 10.1.1.1 0.0.0.0
or
deny all
HTH>
Re: ACL Issue.
or
deny all
HTH>
Re: ACL Issue.
Thank you so much! The last permit you did I was supposed to have a 10.1.1.0 0.0.0.255 and then the deny all and it worked!
I cannot believe I missed it by one one digit. I appreciate your help :)
Re: ACL Issue.
np - glad to help.
Re: ACL Issue.
Hello
Sorry but I still have some problems with configuration. I don't know why its not moving from 95 %. I will attached my PT file.
Will you please inform me R1 or R2 configuration?
Looking forward to your kind reply
Re: ACL Issue.
Hey
Do you still have your file?
Re: ACL Issue.
I do not use Packet Tracer.
Re: ACL Issue.
Thanks a lot for your concern
Attached you can find the running config of R1 & R3 in text file.
Thanks about careing
Re: ACL Issue.
OK - I have the files, what is your issue?
Re: ACL Issue.
hi all
i've done 97%, only problem with this
Using extended ACLs on R2, complete the following requirements:
  • Name the ACL block
  • Prohibit traffic originating from the R1 connected subnets from reaching the R3 connected subnets.
  • Prohibit traffic originating from the R3 connected subnets from reaching the R1 connected subnets.
  • Permit all other traffic.
could anyone help
thanx beforehand
Re: ACL Issue.
Use the below
ip access-list extended R1<>R3
  5 deny ip 10.1.1.0 0.0.0.255 10.3.1.0 0.0.0.255
10 deny ip 10.1.1.0 0.0.0.255 10.3.0.0 0.0.0.3
15 deny ip 10.1.0.0 0.0.0.3 10.3.1.0 0.0.0.255
20 deny ip 10.1.0.0 0.0.0.3 10.3.0.0 0.0.0.3
25 permit ip any any
ip access-list extended R3<>R1
  5 deny ip 10.3.1.0 0.0.0.255 10.1.1.0 0.0.0.255
10 deny ip 10.3.0.0 0.0.0.3 10.1.1.0 0.0.0.255
15 deny ip 10.3.1.0 0.0.0.255 10.1.0.0 0.0.0.3
20 deny ip 10.3.0.0 0.0.0.3 10.1.0.0 0.0.0.3
int serial <>
ip access-group R3<>R1 out
int serial <>
ip access-group R1<>R3 out
There is a simpler way of doing the above, you should be able to find it from using the above config.
Re: ACL Issue.
Dear Shehriyar
ip access-list extended block
permit ip any any
Can I see your configuration for R1 & R3?
Re: ACL Issue.
dear sahand
you can check  R1 and R3  configurations, no problem
i've wrote that configurations for R2
but when i check results it only denies block acl
Re: ACL Issue.
Dear shehiyar
erase all R2 configuration and reload it again.
This is my R2 Running config.
I check it again now for you, it will works:
Building configuration...
Current configuration : 1061 bytes
version 12.3
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R2
enable secret 5 $1$mERr$9cTjUIEqNGurQiFU.ZeCi1
ip ssh version 1
no ip domain-lookup
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 10.1.0.2 255.255.255.252
ip access-group block in
interface Serial0/0/1
ip address 10.3.0.1 255.255.255.252
clock rate 64000
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.1.0.0 0.0.0.3 area 0
network 10.3.0.0 0.0.0.3 area 0
ip classless
permit ip any any
no cdp run
line con 0
password cisco
login
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
check it again
What is your R1 & R3?
Re: ACL Issue.
sahad, i've the same configuration for R2 with yours
i couldn''t understand your question but   if you are asking for R1 and R3 password it is    class
Re: ACL Issue.
Thanks Pal
5032
