ACL issue
Hi Amrit,
I have a simple configuration, a DSL, some users browsing internet and sending/receiving e-mails,
and there's a public web server.
It seems to be all up and running, but in order to publish web server I have to open a lot of tcp ports
other than 80, because web server seems to answer through the port owned by client starting request.
This is the configuration:
webserver 192.168.100.253 , public 212.110.x.y, it's the LAN's proxy server
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no aaa new-model
ip subnet-zero
no ip source-route
!ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
ip address 192.168.101.254 255.255.255.0 secondary
ip address 192.168.100.254 255.255.255.0
ip access-group 101 in
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxxxxxxxxxxxxx
ppp chap password yyyyyyyyyyyyyyyyyyyy
ip nat inside source list 10 interface Dialer0 overload
ip nat inside source static tcp 192.168.100.253 22 212.110.x.y 22 extendable no-alias
ip nat inside source static tcp 192.168.100.253 80 212.110.x.y 80 extendable no-alias
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
access-list 10 permit 192.168.100.0 0.0.0.255
dialer-list 1 protocol ip permit
access-list 101 permit icmp any any
access-list 101 permit tcp host 192.168.100.253 any eq domain
access-list 101 permit udp host 192.168.100.253 any eq domain
access-list 101 permit tcp host 192.168.100.253 any eq www
access-list 101 permit tcp host 192.168.100.253 any eq smtp
access-list 101 permit tcp host 192.168.100.253 any eq ftp
access-list 101 permit tcp host 192.168.100.253 any eq pop3
access-list 101 permit tcp host 192.168.100.253 any eq 1433
access-list 101 permit tcp 192.168.100.0 0.0.0.255 any eq pop3
access-list 101 permit tcp 192.168.100.0 0.0.0.255 any eq 1433
access-list 101 permit tcp 192.168.100.0 0.0.0.255 any eq ftp
access-list 101 permit tcp host 192.168.100.253 any range 0 10000 (without this line web is not published)
access-list 101 deny ip any any
line con 0
exec-timeout 120 0
login local
no modem enable
stopbits 1
line aux 0
line vty 0 4
access-class 30 in
exec-timeout 120 0
login local
scheduler max-task-time 5000
end
Alberto Brivio
1 REPLY
Re: ACL issue
The web connection you are trying to filter are from
Any(dynamic port) to your web server(port 80)
This behavior is not changeble. I would modified your ACL to filter on incoming port, not outgoing.
access-list 101 permit tcp host 192.168.100.253 eq 80 any range 0 10000(You might reconsider the range, I think it depend on the client OS, better of with any ports)
114
