ACS 3.2 Installation
I have an existing ACS 2.6(3) server. I'm building a new ACS 3.2 server. I want to export the configuration from the existing server to the new server. I have successfully exported then imported the users and groups, however I can not figure out how to export the administrators and NAS list. I have searched and can not find the correct csutil command for this information. Any ideas?
1 REPLY
Re: ACS 3.2 Installation
i dont think you are folllowing the right procedure.
you needed to run the setup of acs3.2 on top of acs2.6.3 and let the database be upgraded. thats the only solution. in order to get NAT you need database export/import. which you can't do from ACS2.6.3 to ACS 3.2
Nadeem
83
