07-12-2002 01:11 PM - edited 03-08-2019 11:32 PM
What is the best way to transfer ACS 2.3 users and settings on one NT4 box to ACS 3.0 on another W2K box?
07-13-2002 03:01 AM
There are several ways, but best is doing DATABASE REPLICATION.
How?
Upgrade you ACS 2.x on NT to ACS 3.0
then, configure it as Primary ACS server and the other 3.0 on W2k as Secondary ACS.
Perform Replication, and the entire database and configuration will be replicated across.
Note that to perform Database Replication, both ACS must be same version and same build eg; ACS 3.0 build 40
VERY IMPORTANT
There is a known bug, that Database Replication fails after upgrading from 2.x to 3.0. There is a patch available to fix this after upgrading the 2.x to 3.0. Refer to the following
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/csnt30/rn301.htm#xtocid28
Bug ID CSCdw22345: Replication fails on an upgraded ACS
Following URL will walk you through the configuring Replication.
R/Yusuf
07-19-2002 11:33 AM
I have a similar situation with a cisco secure v2.1 server. I would like to move the (500+) user/groups to a different machine on version 3. I don't want upgrade the existing machine, it is not running very well, I am not sure it would survive an upgrade. Can I do a database dump or backup on the v.2.1 machine and have the 3.0 machine import it? If not, ideas?
07-19-2002 10:25 PM
You can use the csutil utility to export the users/group to a text file (dump.txt) and import it on ACS 3.0
eg;
----to dump use -d argument
net stop csauth
csutil -d dump.txt
net start csauth
----to resotre use - L argument
net stop csauth
csutil - l dump.txt
net start csauth
Read the following URL for more info
R/Yusuf
11-08-2002 12:12 PM
I have just done this, but it did not pull in my network configuration. I have hundreds of devices configured there and don't want to re-type them in. Is there a utility for those devices?
